NXC: whats wrong with string SLAVE[4]; ?
// Name of the Slave NXT.
string SLAVE[4];
SLAVE[0]= "000";  // dummy
SLAVE[1]= "001";
SLAVE[2]= "002";
SLAVE[3]= "003";
I get the compiler error
# Error: ';' expected
File "c:\Temp\temp.nxc" ; line 22
# SLAVE[
File "c:\Temp\temp.nxc" ; line 23
# SLAVE[
File "c:\Temp\temp.nxc" ; line 24
# SLAVE[
File "c:\Temp\temp.nxc" ; line 25
# SLAVE[
the same it is when I use
int TONE[5];
TONE[0]=TONE_C4;
TONE[1]=TONE_E4;
TONE[2]=TONE_G4;
TONE[3]=TONE_C5;
TONE[4]=TONE_E5;
mcsummation
Re: NXC: whats wrong with string SLAVE[4]; ?
Post by mcsummation »
Is it within the scope of a task, sub, etc.? Or is this up in the declarations part of the code (up top)? I got it to compile by putting in the task main() area.
they all are global variables at the very top of the code
mcsummation
But, you cannot put assignment statements outside the scope of a task, sub, function, etc. SLAVE[0]= "000"; is an assignment statement.
You either need to use
    string SLAVE[4] = {"000","001","002","003"};
or move the assignment statements into an initialization routine.
uuuh, yes -
the error report was misleading complaining about ";"
mcsummation
Almost always, the ";" complaint is on the line below the actual error. The source scanner has scanned the first and second lines before it finds a "statement end" delimiter, which is usually a ";" or "}", then it says, "Man this statement makes no sense at all. Give the programmer an error and let him figure out what's wrong".
Oh, BTW, I see lots of "missing ;" errors. I let the compiler proofread my code :D
Users browsing this forum: Semrush [Bot] and 29 guests
