preprocessor output
mcsummation
preprocessor output
Is it possible to get the preprocessor's output dumped to a file? (Especially when it gets an error.) I'm having troubles getting a macro to compile properly and I can't determine what the problem is. I know it's probably something simple, but with the stuff going on with token substitution, etc., it's hard to tell what the preprocessor is spitting out.
McSummation aka James
Re: preprocessor output
Sometimes it is faster to just post your code. If you get a preprocessor error I don't you can get any kind of intermediate output. You can try -nbc=<filename> in the switches to see what it outputs.
If you are using BCC, try pressing F12 after compiling the program.
mcsummation
F12 gives the output of the NXC compiler that is the input to the NBC assembler.
John, I was trying to KISS, that's what led me off into the weeds.
