c++ bluetooth nxc comunication library
psorek
Post by psorek »
I have to send some simple informations (probably strings) from computer (program in C++) to NXT.
http://www.norgesgade14.dk/bluetoothlibrary.php
doesn't work, (compilation problems) and i haven't found another. May i please a link, best with simple tutorial in?
mcsummation
Re: c++ bluetooth nxc comunication library
Post by mcsummation »
I have used that library for a number of projects. What compiler are you using and what errors do you get?
psorek
Post by psorek »
CodeBlocks with g++ for windows. Error:
C:\Users\psorek\Desktop\NXT Ploter\GRRRR\sound.h|35|error: extra qualification 'Sound::' on member 'Sound'|
C:\Users\psorek\Desktop\NXT Ploter\GRRRR\sound.h|40|error: extra qualification 'Sound::' on member 'Sound'|
C:\Users\psorek\Desktop\NXT Ploter\GRRRR\sound.h|47|error: extra qualification 'Sound::' on member 'print'|
C:\Users\psorek\Desktop\NXT Ploter\GRRRR\rcx_light.h|17|error: extra qualification 'Light_rcx::' on member 'Light_rcx'|
C:\Users\psorek\Desktop\NXT Ploter\GRRRR\rcx_light.h|21|error: extra qualification 'Light_rcx::' on member 'Light_rcx'|
||=== Build finished: 5 errors, 0 warnings ===|
Code copied from project's site.
mcsummation
I don't see the error in the version of sound.h that I have.
Are you trying to use the two header files that cause the errors? If not, don't include them in the project.
psorek
Post by psorek »
what version of gcc do you use and what compile flags?
psorek
Post by psorek »
problem is when:
class xyz
    xyz::methode (..);
which is used in all of the library. Do i have strange version of compiler, or it is uncompatible with c++ standard?
bullestock
Post by bullestock »
psorek wrote:problem is when:
class xyz
    xyz::methode (..);
gcc is correct here. Putting the xyz:: prefix in the class declaration is not valid C++. It is however allowed by Visual C++, which is what the author of the library uses.
So just remove them all.
psorek
Post by psorek »
It is not nice. How can i install ONLY Visual C++ compiler? w/o IDE?
psorek
Post by psorek »
Yeah, it works now. Someone should improve it.
