I have made one update to the planitary system. Since the main drive input to the sytem had 1 8z in the center of the palitary that gettes loaded at 4 angles. But each main gear has 2 8z contacting the LT(lagre turtables). This that means that 1 8z withe 4 contact points was loaded with 8-8z in the end. The new system is one brick widder but doubles the power out by useing two 8z at center and all other gears doubled up. This Super joint now was enough power out to give all 8z's to the LT full power without the issue if over loaded that center single gear could strip out. This is weight at a very high working load, the new one I have yet to break it but I think now the 8-8z at the LT could skip if over loaded, these gears are now held by 8 axles with stops as well these seem to improve this area of contact as well.
These pics are of a basic Single Semi planitary. To make a Double just double it up.
Right now X-2 is in rebuild to now have 5dof legs each. This adds 2dof to each leg that is a leaning function(for more advanced ankle and hip side to side flex. This has been a huge issue in makeing an assemby that can take loads and be flexible, compact and have this working load to handle these extreme loads.
At first i was making just more planitarys though this worked it adds ALOT of weight, was not compact enough. Linear rams would be a better choice, but issues have been reprorted with our Lego La's. Fernnellii would be an option but have been out of stock a long time, perhasp they have an issue as well? So i found that at the ankles I may use 4or8 Lego La. I have two on a side now but i can see a 4 ram working there better. The hips will crush a Lego La. So I built a Linear ram of tecnic parts. 9x5x11 This ram is a redundant system as well 4 drive and 4 idle(the idle could be powered as well doubling its power as well to 8. Twin/twin worms drive at 72:1. mounted in the hip.
This was an atempt at all geared 10dof To tall, gangilly and much to heavy(notice single planitary's here)
My Technic Ram for hip lean.
So now here is One leg completed to the HIp area and a ankle.
So If this works out It will shift weight in a more Human way and much more complex as well.
