My new NXT game- After Dark, in grayscale
Re: My new game- After Dark
and please where's the code?
nxtboyiii
Post by nxtboyiii »
Umm.... I can probably give you the code later today.
BE WARNED: The code is verrrrrrrrrrrrrrryyyyyyyyyy messy. :oops:
Re: My new NXT game- After Dark, in grayscale
maybe you wish to polish it up before publishing it (e.g. exchanging gibberish by expressive keywords and inserting correct white space / tabs, and MAYBE write some comments...?)
nxtboyiii
Post by nxtboyiii »
I'll just post the .rics and the executable.
Here ya go.
Just drag all the files to the NXT.
For best grayscale performance, don't use the NXT Screen utility in Bricxcc while playing the game.
After Dark.zip
My game, After Dark
(17.43 KiB) Downloaded 934 times
nxtboyiii
Post by nxtboyiii »
So what do you think of it?
the code is what I was curious of
(BTW why didn't you delete your double post?)
nxtboyiii
Post by nxtboyiii »
But what do you think of the game?
Do you like the grayscale?
yes, it's really remarkable!
nxtboyiii
Post by nxtboyiii »
Well since you already have all the .rics, here's the code:
int mapx,mapy;
float fmapx,fmapy;
int xadd,yadd;
int xadd2,yadd2;
byte map[25][5];
byte width=25;
byte height=5;
int x,y;
int paddx,paddy;
int xpp,ypp;
int xd,yd;
bool executeMe;
int xdd,ydd;
int xdd2,ydd2;
bool bAddP;
byte NUMOFENEMIES=6;
byte weapon_in_use;
bool attack;
bool DrawParticles;
float particlex[10];
float particley[10];
float particleax[10];
float particleay[10];
int particlepower;
int particleangle;
int particle_timer;
bool canattack;
bool deademy;
byte particle_count;
byte gib_var[1];
unsigned long t0z;
int life;
byte wpn_width[8];
string weapon_filename;
bool paused,shop;
int sely;
byte wpn_cost[8];
int money=300;
int bulletx[6];
int bullety[6];
bool active_bullets[6];
int befbulletx[6];
int bul;
int bulletspeed;
bool bDisplayWhiteOut;
int zomspeed=2;
int zomlife=10;
 DrawGraphicType plyr;
struct enemy
 int x;
 int y;
 char life;
 byte var1;
 bool zom_move;
 byte zom_move_timer;
 byte var2;
enemy emy[NUMOFENEMIES];
void EnemyInit(byte index, byte enemytype, byte enmapx, byte enmapy, char life)
// emy[index].enemytype=enemytype;
// emy[index].mapx=enmapx;
// emy[index].mapy=enmapy;
 emy[index].life=life;
 emy[index].x=enmapx*16;
 emy[index].y=enmapy*16;
// emy[index].fmapx=enmapx;
// emy[index].fmapy=enmapy;
// emy[index].xpp=enmapx*16;
// emy[index].ypp=enmapy*16;
#define bLeft ButtonPressed(BTNLEFT,0)
#define bRight ButtonPressed(BTNRIGHT,0)
#define bCenter ButtonPressed(BTNCENTER,0)
#define bExit ButtonPressed(BTNEXIT,0)
#define RIGHT 0
#define WALKRIGHT 27
#define LEFT 54
#define WALKLEFT 81
#define GRASS 0
#define QUESTION 1
#define SKELIBOTTOM 2
#define SKELITOP 5
#define GRAVESTONE 73
#define DARK 72
#define AIR 74
#define GOOMBATILE 60
#define TORCH 62
#define FIRE 132
#define STONE 4
#define TNT 3
#define ZOMBIE 0
#define SWORD 0
#define LONGSWORD 1
#define STAFF 2
#define PISTOL 3
#define MACHINEGUN 4
void PlaceSkeletonStatue(byte _x, byte _y)
 map[_x][_y]=SKELIBOTTOM;
 map[_x][_y+1]=SKELITOP;
task tiles()
 int cen,den;
 byte var[1];
 DrawGraphicType gargs;
 DrawGraphicType enemygraphic;
 ArrayInit(gargs.Variables,0,35);
 ArrayInit(enemygraphic.Variables,0,2);
  ArrayInit(plyr.Variables,0,2);
  plyr.Filename="man.ric";
 unsigned long t0;
 byte mapt[35]; //7x5 + setting
 byte yt;
 byte v;
 byte animation_loop;
 string enemyfilename;
 byte temp_enemy_var[1];
 byte weapon_var[2];
 char weapon_x_add;
 bool canattack;
 bool canattack2;
 bool pressed;
 bool shoot;
 unsigned long endtime;
 byte menuvar[1];
 byte healthvar[1];
 string fn;
 enemygraphic.Filename="emy_zombie.ric";
 enemy tdemy;
 while(1)
   xadd2=xadd;
   yadd2=yadd;
   ydd2=ydd;
   xdd2=xdd;
  cen=floor(xadd2/-16)+7;
  den=floor(yadd2/-16)+5;
  yt=0;
   if(!paused)
    for(int cc=floor(xadd2/-16); cc < cen; cc++)
   for(int dd=floor(yadd2/-16); dd < den; dd++)
    v=map[cc][dd];
/*    if(animation_loop == 1)
    if(v >= 132)
           if(frac(v/2.0) == 0) //If v is even
       v++;
      else                 //If v is odd
       v--;
      map[cc][dd]=v;
    else if(v >= 60)
     if(v <= 71)
       v++;
      else                 //If v is odd
       v--;
      map[cc][dd]=v;
    mapt[yt]=v;
    yt++;
   animation_loop++;
   if(animation_loop == 3)
    animation_loop=0;
  if(bRight)
   if(plyr.Variables[1] == RIGHT)
    plyr.Variables[1]=WALKRIGHT;
    plyr.Variables[1]=RIGHT;
     weapon_x_add=15;
     weapon_var[1]=0;
   else if(bLeft)
   if(plyr.Variables[1] == LEFT)
    plyr.Variables[1]=WALKLEFT;
    plyr.Variables[1]=LEFT;
     weapon_x_add=(wpn_width[weapon_in_use]-1)*-1;
     weapon_var[1]=8;
    if(plyr.Variables[1] == WALKLEFT)
    else if(plyr.Variables[1] == WALKRIGHT)
  attack=0;
  if(weapon_x_add == 18)
  weapon_x_add=15;
  else if(weapon_x_add == -10)
  weapon_x_add=-7;
  if(SENSOR_1)
    pressed=1;
    if(weapon_in_use == MACHINEGUN)
     shoot=1;
      if(weapon_in_use == PISTOL)
     if(canattack)
      canattack=0;
      shoot=1;
    else if(canattack)
    canattack=0;
    attack=1;
    if(plyr.Variables[1] == RIGHT || plyr.Variables[1] == WALKRIGHT)
    weapon_x_add=18;
    else if(plyr.Variables[1] == LEFT || plyr.Variables[1] == WALKLEFT)
    weapon_x_add=-10;
    if(shoot)
     shoot=0;
          active_bullets[bul]=1;
     bulletx[bul]=x+16+wpn_width[weapon_in_use];
     befbulletx[bul]=x+16+wpn_width[weapon_in_use];
     bulletx[bul]=x-wpn_width[weapon_in_use];
     befbulletx[bul]=x-wpn_width[weapon_in_use];
     bullety[bul]=y+11+Random(3);
     if(bul < 6)
     bul++;
     bul=0;
    bulletspeed=6;
    bulletspeed=-6;
    bulletspeed=15;
    bulletspeed=-15;
  Wait(17-(CurrentTick()-t0));
  SetDisplayFlags( DISPLAY_REFRESH_DISABLED );
  plyr.Location.X=x;
  plyr.Location.Y=y;
  gargs.Filename="pic1.ric";
    gargs.Variables=mapt;
    gargs.Location.X=xdd2;
    gargs.Location.Y=ydd2;
    SysDrawGraphic(gargs);
     for(int c=0; c < NUMOFENEMIES; c++)
    if(emy[c].life > 0)
     if(emy[c].x <= 96 && emy[c] >= -15)
      tdemy=emy[c];
/*     switch(tdemy.enemytype)
      case ZOMBIE:
      break;
  if(tdemy.var2 == 0 || tdemy.var2 == 48)
   tdemy.var2+=24;
   tdemy.var2-=24;
     enemygraphic.Variables[1]=tdemy.var2;
     enemygraphic.Variables[0]=tdemy.var1;
     enemygraphic.Location.X=tdemy.x;
     enemygraphic.Location.Y=tdemy.y;
     SysDrawGraphic(enemygraphic);
     tdemy.var1+=16;
     emy[c]=tdemy;
       plyr.Variables[0]=0;
  SysDrawGraphic(plyr);
  weapon_var[0]=0;
   GraphicOutEx(x+weapon_x_add,y+10,weapon_filename,weapon_var);
   if(DrawParticles)
       particle_timer++;
       if(!deademy)
        if(particle_timer >= 10)
         DrawParticles=0;
       else if(particle_timer >= 20)
        DrawParticles=0;
        deademy=0;
      for(int c=0; c < particle_count; c++)
/*   particlex[c]+=particleax[c];
   particley[c]+=particleay[c];
   particlepower--;
   if(particlepower <= 0)
    particleay[c]-=0.2;
   particley[c]-=0.2;*/
         if(c == 13)
    fn="zomhead.ric";
   fn="gib.ric";
   GraphicOutEx(particlex[c],particley[c],fn,gib_var);
   if(paused)
    menuvar[0]=0;
    GraphicOutEx(16,0,"menu_back.ric",menuvar);
    if(!shop)
     TextOut(25,LCD_LINE1,"Unpause");
     TextOut(25,LCD_LINE2,"Shop");
     TextOut(25,LCD_LINE1,"Exit Shop");
     TextOut(25,LCD_LINE2,"Long Sword");
     TextOut(25,LCD_LINE3,"Staff");
     TextOut(25,LCD_LINE4,"Pistol");
     TextOut(25,LCD_LINE5,"Mach-Gun");
     TextOut(25,LCD_LINE8,StrCat("Cost$",NumToStr(wpn_cost[sely/-8+7])," $", NumToStr(money)));
    RectOut(23,sely,54,8,DRAW_OPT_FILL_SHAPE | DRAW_OPT_LOGICAL_XOR);
   for(int c=0; c < 6; c++)
    if(active_bullets[c])
     LineOut(bulletx[c],bullety[c],bulletx[c]+3,bullety[c],DRAW_OPT_INVERT);
/*     if(bDisplayWhiteOut)      //Display "White out" effect when bDisplayWhiteOut == true, which is when the character is hurt
      bDisplayWhiteOut=false;
      ClearScreen();
        healthvar[0]=0;                             //Sets up variable for healthvar so it can be grayscale
   GraphicOutEx(0,62,"health-back.ric",healthvar); //Draw the health bar
     RectOut(0,62,life,1,DRAW_OPT_LOGICAL_XOR);
  SetDisplayFlags( DISPLAY_ON | DISPLAY_REFRESH );
  Wait(17);
      if(pressed)
  if(!SENSOR_1)
     pressed=0;
   canattack=1;
     //   ClearScreen();
    gargs.Filename="pic2.ric";
    if(emy[c].life > 0)
     tdemy=emy[c];
      case ZOMBIE:
      break;
   tdemy.var2+=24;
   tdemy.var2-=24;
     tdemy.var1+=16;
     emy[c]=tdemy;
        plyr.Variables[0]=16;
  weapon_var[0]=wpn_width[weapon_in_use];
      if(DrawParticles)
   particlepower--;
    particleay[c]-=0.2;
   particley[c]-=0.2;
      if(c == 13)
    fn="zomhead.ric";
   fn="gib.ric";
   if(paused)
    menuvar[0]=68;
    if(!shop)
   healthvar[0]=40;
   RectOut(0,62,life,1,DRAW_OPT_LOGICAL_XOR); //Draw the health bar
  Wait(17);
  if(SENSOR_1)
   pressed=1;
//  ClearScreen();
  gargs.Filename="pic3.ric";
    if(emy[c].life > 0)
     tdemy=emy[c];
      case ZOMBIE:
      break;
   tdemy.var2+=24;
   tdemy.var2-=24;
      tdemy.var1=0;
      emy[c]=tdemy;
       plyr.Variables[0]=32;
  weapon_var[0]=wpn_width[weapon_in_use]*2;
      if(DrawParticles)
   particlepower--;
    particleay[c]-=0.2;
   particley[c]-=0.2;
      if(c == 13)
    fn="zomhead.ric";
   fn="gib.ric";
   if(paused)
    menuvar[0]=136;
    if(!shop)
      healthvar[0]=80;
  t0=CurrentTick();
  if(weapon_in_use != PISTOL)
  if(attack)
   if(!SENSOR_1)
   canattack2=1;
   canattack2=0;
  canattack2=1;
/*    if(pressed)
   pressed=0;
  if(!SENSOR_1)
   canattack=1;
  canattack=0;
task engine()
 Wait(300);
 char starthitcheck, endhitcheck;
 enemy temy;
 while(1)
            paddx=fmapx == floor(fmapx)?0:1;
//  mapy=floor(fmapy);
  paddy=fmapy == floor(fmapy)?0:1;
      //startleft
  if(bLeft)
   executeMe=false;
      if(map[mapx-1][mapy] >= DARK)
    if(map[mapx-1][mapy+paddy] >= DARK)
     executeMe=true;
   else if(fmapx > floor(fmapx))
   executeMe=true;
    if(executeMe)
     xpp-=4;
     fmapx=xpp/16;
     if(xadd == 0)
      xd=0;
      x-=4;
     else if(x == 32)
      xd+=4;
     else if(x > 32)
      xd=0;
      x-=4;
  //finishleft
  mapx=floor(fmapx);
        //startright
  if(bRight)
      executeMe=false;
      if(map[mapx+1][mapy] >= DARK)
    if(map[mapx+1][mapy+paddy] >= DARK)
     executeMe=true;
    if(executeMe)
     xpp+=4;
     fmapx=xpp/16;
     if(xadd/-16.0 < width-7 && x == 32)
      xd-=4;
      xd=0;
      x+=4;
  //finishright
     mapx=floor(fmapx);
  mapx=floor(fmapx);
     xadd+=xd;
   yadd+=yd;
   xdd+=xd;
   ydd+=yd;
         if(frac(xdd/-16.0) == 0)
   xdd=0;
  else if(xdd > 0)
   xdd-=16;
    if(frac(ydd/-16.0) == 0)
   ydd=0;
    else if(ydd > 0)
   ydd-=16;
  if(bCenter)
   until(!bCenter);
   paused=true;
   sely=LCD_LINE1;
   until(bCenter && sely == LCD_LINE1 && !shop)
    if(bLeft && sely != LCD_LINE1)
     until(!bLeft);
     sely+=8;
    if(bRight)
     until(!bRight);
     sely-=8;
    if(bCenter)
     until(!bCenter);
     if(!shop)
      if(sely == LCD_LINE2)
       shop=1;
            if(sely == LCD_LINE1)
       goto outofpause;
       shop=0;
      if(sely <= LCD_LINE2)
       if(money >= wpn_cost[sely/-8+7])
        weapon_in_use=sely/-8+7;
        money-=wpn_cost[sely/-8+7];
        PlayToneEx(600,200,1,0);
        Wait(200);
        PlayToneEx(800,200,1,0);
        Wait(200);
             switch(weapon_in_use)
   case SWORD:
   weapon_filename="wpn_sword.ric";
   break;
   case LONGSWORD:
   weapon_filename="wpn_lngsword.ric";
   break;
   case STAFF:
   weapon_filename="wpn_staff.ric";
   break;
   case PISTOL:
   weapon_filename="wpn_pistol.ric";
   break;
      case MACHINEGUN:
   weapon_filename="wpn_mgun.ric";
   break;
        Wait(200);
        PlayToneEx(400,200,1,0);
        Wait(200);
   outofpause:
        Wait(200);
        Wait(200);
   until(!bCenter);
   paused=false;
  t0z=CurrentTick();
    bulletx[c]+=bulletspeed;
    if(bulletspeed >= 1)
     if(bulletx[c] >= 120)
      active_bullets[c]=0;
     if(bulletx[c] <= -40)
    if(emy[c].life > 0)
     temy=emy[c];
     temy.x+=xd;
     temy.y+=yd;
   executeMe=false;
/*      if(map[temy.mapx-1][temy.mapy] >= DARK)
/*    if(map[temy.mapx-1][temy.mapy+temy.paddy] >= DARK)
//     executeMe=true;
/*     for(int f=0; f < NUMOFENEMIES; f++)
      if(f != c)
      if((((temy.x + 16) >= emy[f].x) && (temy.x <= (emy[f].x + 16))))
       executeMe=false;
       goto eol;
     eol:*/
//   else if(temy.fmapx > floor(temy.fmapx))
 //  executeMe=true;
//    if(executeMe)
//     temy.xpp-=2;
 //    temy.fmapx=temy.xpp/16.0;
 temy.zom_move_timer++;
 if(temy.zom_move_timer >= 4)
  temy.zom_move_timer=0;
  if(Random(2) == 0)
  temy.zom_move=1;
  temy.zom_move=0;
 if(temy.zom_move)
 if(temy.x > x+16)
      temy.x-=zomspeed;
                   if(temy.var2 == 48 || temy.var2 == 72)
      temy.var2=0;
      else if(temy.x < x)
       temy.x+=zomspeed;
            if(temy.var2 == 0 || temy.var2 == 24)
      temy.var2=48;
   // temy.mapx=floor(temy.fmapx);
    //temy.paddx=temy.fmapx == floor(temy.fmapx)?0:1;
    if(attack)
      endhitcheck=wpn_width[weapon_in_use]-1;
      starthitcheck=0;
      endhitcheck=0;
      starthitcheck=(wpn_width[weapon_in_use]-1)*-1;
      endhitcheck=0;
      starthitcheck=0;
     for(int b=0; b < 6; b++)
      if(active_bullets[b])
      if(bulletspeed > 0)
     if((bulletx[b]+10 >= temy.x) && (bulletx[b]-(bulletx[b]-befbulletx[b]) <= (temy.x + 16)))
      active_bullets[b]=0;
      goto hurtzom;
           if(((bulletx[b] - (bulletx[b]-befbulletx[b])) >= temy.x) && (bulletx[b] <= (temy.x + 16)))
      goto hurtzom;
     befbulletx[b]=bulletx[b];
     if(((x + 16 + endhitcheck) >= temy.x) && (x + starthitcheck <= (temy.x + 16)))
         if(attack)
     hurtzom:
      particle_timer=0;
      PlayFile("hit_blood_spat.rso");
      temy.life--;
      particle_count=6;
      particlepower=10;
       for(int e=0; e < Random(particle_count-2)+2; e++)
  particleangle=Random(40)-10;
  particleax[e]=cosd(particleangle)*6;
  particleay[e]=sind(particleangle)*6;
  particlex[e]=temy.x+8;
  particley[e]=temy.y+8;
       DrawParticles=1;
  life--;
  //PlayFile("zattack.rso");
//  bDisplayWhiteOut=true;
  if(life <= 0)
   StopTask(tiles);
   Wait(500);
   byte vartt[1];
   until(ButtonPressed(BTNCENTER,0))
         vartt[0]=0;
  GraphicOutEx(0,0,"death.ric",vartt);
  Wait(17);
  vartt[0]=100;
  Wait(17);
  vartt[0]=200;
  Wait(17);
   Wait(100);
   StopAllTasks();
    if(temy.life <= 0)
           deademy=1;
           money+=5;
      particle_timer=0;
      particlepower=40;
      particle_count=10;
      temy.life=zomlife;
       for(int e=0; e < 15; e++)
  particleangle=Random(220)-20;
  particleax[e]=cosd(particleangle)*7;
  particleay[e]=sind(particleangle)*7;
  if(e == 13)
  particleangle=88+Random(6);
  particleax[e]=cosd(particleangle)*8;
  particleay[e]=sind(particleangle)*8;
 }     if(xadd <= -20)
        switch(Random(2))
         case 0:
         temy.x=xadd+1*16;
         break;
         case 1:
         temy.x=xadd+17*16;
         break;
       temy.x=xadd+17*16;
      temy.y=yadd+16;
            DrawParticles=1;
    emy[c]=temy;
         xd=0;
   yd=0;
   Wait(120-(CurrentTick()-t0z));
 SetSensorTouch(S1);
 gib_var[1]=DRAW_OPT_LOGICAL_XOR;
 for(int c=0; c < width; c++)
  for(int d=0; d < height; d++)
   map[c][d]=DARK;
  map[c][0]=GRASS;
  map[c][height-1]=GRASS;
  for(int c=0; c < height; c++)
  map[0][c]=GRASS;
  map[width-1][c]=GRASS;
// PlaceSkeletonStatue(11,1);
 EnemyInit(0,ZOMBIE,12,1,zomlife);
 EnemyInit(1,ZOMBIE,15,1,zomlife);
 EnemyInit(2,ZOMBIE,18,1,zomlife);
 EnemyInit(3,ZOMBIE,20,1,zomlife);
 EnemyInit(4,ZOMBIE,22,1,zomlife);
 EnemyInit(5,ZOMBIE,16,1,zomlife);
/* EnemyInit(6,ZOMBIE,17,1,6);
 EnemyInit(7,ZOMBIE,18,1,6);
 EnemyInit(8,ZOMBIE,19,1,6);
 EnemyInit(9,ZOMBIE,20,1,6);
 EnemyInit(10,ZOMBIE,18,1,6);
 EnemyInit(11,ZOMBIE,19,1,6);
 EnemyInit(12,ZOMBIE,20,1,6);
 EnemyInit(13,ZOMBIE,21,1,6);
 EnemyInit(14,ZOMBIE,22,1,6);*/
 map[13][1]=GRAVESTONE;
 map[16][1]=GRAVESTONE;
 map[18][1]=GRAVESTONE;
 mapx=2;
 mapy=1;
 fmapx=2;
 fmapy=1;
 x=32;
 y=16;
 xpp=mapx*16;
 ypp=mapx*16;
 byte vartt[1];
 life=40;
 wpn_width[0]=8;
 wpn_width[1]=13;
 wpn_width[2]=20;
 wpn_width[3]=8;
 wpn_width[4]=8;
 wpn_cost[1]=30;
 wpn_cost[2]=50;
 wpn_cost[3]=70;
  wpn_cost[4]=120;
 weapon_in_use=SWORD;
   case SWORD:
   break;
   case LONGSWORD:
   break;
   case STAFF:
   break;
   case PISTOL:
   break;
      case MACHINEGUN:
   break;
 SetDisplayContrast(83);
    vartt[0]=0;
  GraphicOutEx(0,0,"title.ric",vartt);
  Wait(17);
  vartt[0]=100;
  Wait(17);
  vartt[0]=200;
  Wait(17);
 Precedes(tiles,engine);
nxtboyiii
Post by nxtboyiii »
Doc- did you see the code? Do you need help with something?
Does anybody have any comments about this project? It seems as if hardly anybody is commenting.
EDIT: I posted the program (.rxe and .rics) to the game in the main post.
