nxtboyiii
Posts: 366 Joined: 02 Oct 2010, 07:08
Post
by nxtboyiii » 27 Jan 2012, 01:17
If you download muntoo's SCR_FILE_LIB and run this program you will notice how slow the particles move.
**BTW, I did not make the algorithm for this water simulation.
I want the water particles to move faster but still smooth, but I do not know how to do it other than decreasing the # of water particles.
Here's the code:
#include "SCR_File_lib.nxc"
#define NUM_OF_PARTICLES 100
byte map[100][64];
int px[NUM_OF_PARTICLES];
int py[NUM_OF_PARTICLES];
bool pactive[NUM_OF_PARTICLES];
int tpx,tpy;
byte ScreenMem[];
ArrayInit(ScreenMem, 0x00, 800);
ScreenMem[799] = 0x0F;
for(int c=0; c < NUM_OF_PARTICLES; c++)
pactive[c]=1;
for(int c=0; c < 24; c++)
px[c]=40;
py[c]=c+40;
for(int c=24; c < 40; c++)
px[c]=41;
py[c]=c+40-24;
for(int c=40; c < NUM_OF_PARTICLES; c++)
px[c]=42;
py[c]=c;
for(int c=60; c < NUM_OF_PARTICLES; c++)
px[c]=39;
py[c]=c-20;
for(int c=80; c < NUM_OF_PARTICLES; c++)
px[c]=38;
py[c]=c-40;
for(int c=0; c < 100; c++)
map[c][30]=1;
map[c][0]=1;
for(int c=0; c < 64; c++)
map[99][c]=1;
map[0][c]=1;
for(int c=0; c < 20; c++)
map[Random(98)+1][30]=0;
int x,y;
x=30;
y=20;
repeat(20)
x++;
y++;
map[x][y]=1;
x=20;
y=40;
repeat(20)
x++;
y--;
map[x][y]=1;
unsigned long dispAddr; //Draws the map and saves it to ScreenMem
dispAddr = DisplayDisplay();
SetDisplayDisplay(addressOf(ScreenMem));
for(int d=0; d < 64; d++)
if(map[c][d] == 1)
PointOut(c,d);
SetDisplayDisplay(dispAddr);
DisplayScreenMem(ScreenMem);
while(1)
SetDisplayFlags( DISPLAY_REFRESH_DISABLED );
ClearScreen();
if(pactive[c])
tpx=px[c];
tpy=py[c];
map[tpx][tpy]=0;
if(map[tpx][tpy-1] == 0)
tpy--;
else if(map[tpx+1][tpy] == 0)
if(map[tpx-1][tpy] == 0)
tpx+=Random(3)-1;
tpx++;
else if(map[tpx-1][tpy] == 0)
tpx--;
PointOut(tpx,tpy);
map[tpx][tpy]=1;
px[c]=tpx;
py[c]=tpy;
SetDisplayFlags( DISPLAY_ON | DISPLAY_REFRESH );
Wait(17);
mcsummation
Posts: 220 Joined: 23 Jan 2012, 17:07
Post
by mcsummation » 30 Jan 2012, 18:19
Before I bother to download your code and munge through it, what OPT level are you running in the compiler?
nxtboyiii
Post
by nxtboyiii » 01 Feb 2012, 01:58
Optimization level 2.
mcsummation
Post
by mcsummation » 01 Feb 2012, 14:44
Just how fast do you want it to run? I compiled it with the latest compiler and run it on the latest firmware and it runs about as fast as I can comfortably watch the fluid spill into the cone.
It will take me some time to analyze the code and determine what part needs to be worked on.
nxtboyiii
Post
by nxtboyiii » 01 Feb 2012, 15:30
Well I want to be able to have, like 150-200 particles while still running at about as fast as the original program runs 100 particles.
mcsummation
Post
by mcsummation » 01 Feb 2012, 15:34
Oh, OK. Now I understand. Will get back after looking at code.
Posts: 358 Joined: 01 Oct 2010, 06:37
Post
by spillerrec » 01 Feb 2012, 17:19
I gave it a go too, try it out:
#define WIDTH (100)
#define HEIGHT (64)
#define xy( x, y ) ( (y)*WIDTH + (x) )
task main(){
byte map[ WIDTH * HEIGHT ];
int p[NUM_OF_PARTICLES];
byte ScreenMem[];
p[c] = xy( 40, c+40 );
p[c] = xy( 41, c+40-24 );
p[c] = xy( 42, c );
p[c] = xy( 39, c-20 );
p[c] = xy( 38, c-40 );
map[ xy( c, 30 ) ] =1;
map[ xy( c, 0 ) ]=1;
map[ xy( 99, c ) ]=1;
map[ xy( 0,c ) ]=1;
map[ xy( Random(98)+1, 30 ) ]=0;
int x,y;
x=30;
y=20;
repeat(20){
x++;
y++;
map[ xy( x, y ) ]=1;
x=20;
y=40;
repeat(20){
x++;
y--;
for(int c=0; c < 100; c++){
for(int d=0; d < 64; d++){
if(map[ xy( c, d ) ] == 1)
PointOut(c,d);
while(1){
for(int c=0; c < NUM_OF_PARTICLES; c++){
int tp = p[c], org = tp;
if(map[ tp - WIDTH ] == 0)
tp -= WIDTH;
else if(map[ tp + 1 ] == 0){
if(map[ tp - 1 ] == 0)
tp += Random(3)-1;
tp++;
else if(map[ tp - 1] == 0)
tp--;
continue;
map[org] = 0;
map[tp]=1;
p[c]=tp;
int c = NUM_OF_PARTICLES;
do{
int tp = p[--c];
PointOut(tp%WIDTH,tp/WIDTH);
}while( c > 0 );
}The repeated calls to PointOut is costly though, it makes up roughly half of the time for each iteration... : \
EDIT: btw, I threw out the pactive array since it was unused here...
EDIT2: I used optimization level 3 here btw
nxtboyiii
Post
by nxtboyiii » 01 Feb 2012, 18:00
Wow, thanks a ton, spillerec!
I haven't tested it out yet but it looks like this could make it speed up a lot.
Thank you so much.
Have a nice day,
nxtboyIII
Posts: 1818 Joined: 02 Oct 2010, 02:19
Post
by mattallen37 » 01 Feb 2012, 18:21
Here is a slightly modified version of spillerrec's program
while(1){
for(int c=(NUM_OF_PARTICLES-1); c+1; c--){
tp -= WIDTH;
tp += Random(3)-1;
tp++;
tp--;
continue;
map[org] = 0;
map[tp]=1;
p[c]=tp;
asm {set __PointOutArgs.Options, 0}
do{
int tp = p[--c];
asm{
mod __signed_stack_001main, __main_7qG2_tp_7qG2_002, 100
div __D0main, __main_7qG2_tp_7qG2_002, 100
mov __PointOutArgs.Location.X, __signed_stack_001main
mov __PointOutArgs.Location.Y, __D0main
syscall 14, __PointOutArgs
}while(c);
}I don't know if it's noticeably faster, but it
is less op codes.
nxtboyiii
Post
by nxtboyiii » 01 Feb 2012, 19:56
Thanks a lot for the help! Your's and spillerec's help me a lot.
Once I test it out it should be a whole lot faster.
Users browsing this forum: Semrush [Bot] and 24 guests
