Help NXT servo V2. and 2 valves PSMV90
philouchat
Post by philouchat »
I have NXT servo V2. and 2 valves PSMV90
I can not set the parameters of G NXT servo to reverse the orders of the valve and put valve to center.
The goal is to achieve the Snatcher with tires.
Do you have an example to send me this type of program?
Thank you in advance.
cordially
Philippe PASSET
Re: Help NXT servo V2. and 2 valves PSMV90
Never used this but, from what I can see from the Mindsensors website, you put a low number (<1500) in to get it to move to one side followed by a wait to allow the valve to operate. To move to the other side put in a high number. The servo should return to the neutral point after the signal has stopped (end of wait period).
philouchat
Thank you for the info. I looked for a site but I found nothing exept that of Mindsensors. Did you find another site?
Nope - I just looked at the block and sample programs on that site -
http://www.mindsensors.com/index.php?mo ... PAGE_id=93
There is also a couple of guides, but I have not read them -
http://www.mindsensors.com/index.php?mo ... ment_id=69
