Idea: Visual NXC
Re: Idea: Visual NXC
Finally got around to merging the main fork of Visual NXC with the Compiler fork. Some interesting new features added as well:
http://screenr.com/Dlrs
Have a nice day,
~Sidneys1
Have a nice day,
~Sidneys1
That is some impressive work! I am really looking forward to seeing the finished project
I'm thinking of adding a new feature... A sort of hybrid view that shows the blocks, but instead of a simplified piece of text to title the block it shows the actual code-behind.. Just a thought.
~Sidneys1
~Sidneys1
As long as that view is optional, that sounds good.
Or you could have a hover-over 'tool tip' appear that shows a few lines of the code whenever you hover over a block.sidneys1 wrote:A sort of hybrid view that shows the blocks, but instead of a simplified piece of text to title the block it shows the actual code-behind.
By 'hybrid', I am guessing you mean having two panels: the rendered blocks and the source code. (Sort of like Firebug or Chrome Developer Tools docked.)
Not quite... I'll work up a mock later if I have time.muntoo wrote:Or you could have a hover-over 'tool tip' appear that shows a few lines of the code whenever you hover over a block.
Very nice theme
Got bored and had Expression Web 4 on my hands
Only took maybe 5-7 hours total.
Have a nice day,
~Sidneys1
Have a nice day,
~Sidneys1
You should make the header translucent.
BTW, instead of:
You could make it look like
BTW, instead of:
Start: main()
End: main()
while()
main()
Rotate Motor Forward (Port A, 100%)
Wait (2.5s)
while (true)
Wait(42ms)
Wait(42ms)
Wait(42ms)
// End of while 'block'.
// End of main 'block'
