Update rate of NXT screen
nxtboyiii
Re: Update rate of NXT screen
Post by nxtboyiii »
Ok, that shouldn't be too hard.
stryker001
Post by stryker001 »
My thoughts exactly.... but not necessarily the compiler's thoughts :(
nxtboyiii
Post by nxtboyiii »
Does your code not compile? Do you have some code yet? If so, could I please take a look at it?
Thanks
stryker001
my code compiles, it's just that some stuff a friend and I are working on (huge surprise) isn't working due to some kind of bug... it looks like a compiler bug, but we're not entirely sure yet. Since I'm at college right now I can't send you the code, but if you PM me then it'll remind me to send it when I get home. :)
boy this is OT.. in a way...
nxtboyiii
Post by nxtboyiii »
OT:
:( Are you sure you cannot send it? Email? :(
stryker001
I was at college. I don't have a laptop... so I didn't have my code with me. Sorry that was unclear.
Now that I'm home again, I can send it to you. I'll PM it because I can't remember what your email is; if you want it emailed, just reply to the PM with you email address.
nxtboyiii
Post by nxtboyiii »
What exactly is it supposed to be? A bouncy ball?
Where do I set the Accel Sensor to for the default postion? Black part down?
nicknackgus
Post by nicknackgus »
I tried something like this before with 100 .ric images of my cat, created by a threshold effect. I wrote a program that simply displays all of them from darkest to lightest with no waits in NXT-G. The final version required the images to be loaded, the NXT to be defragmented, and then more images and the program had to be loaded, with more defragmenting. This resulted in a grayscale image of my cat, getting brighter and darker as if by dimmer switch over the coarse of a few seconds. Unfortunately, the program and images were lost when a backup disk died.
stryker001
I did it with 16 RICs, only rather than a cat I did my user icon. It was just barely too much and the NXT had the same effect you did, just much faster.
nxtboyiii
Post by nxtboyiii »
Yes, I have actually started making 4 level NXT grayscale games! It is really cool.
Users browsing this forum: Ahrefs [Bot] and 4 guests
