float FindOffset()
float tot = 0;
repeat (1000)
tot += SensorHTGyro(S1, 0); //tot var is 1000 gyro readings
PlayTone(440,500);
return tot / 1000; // returns avg
}Code: Select all
float FindOffset()
float tot = 0;
repeat (1000)
PlayTone(440,500);
}Code: Select all
// IO functions, sensors
#define Menc(a) MotorRotationCount(a)
#define Beep(f,d) PlayTone(f,d)
TextOut(_x, _y, sval1); \
const char LCDline[]={56,48,40,32,24,16,8,0};
const string clrln=" ";
inline bool btnhit(){
return ( ButtonPressed(BTN1, false) || ButtonPressed(BTN2, false)
void PressToContinue(char Button) {
string msg;
if (Button==BTNCENTER) msg="press BtnCntr...";
if (Button==BTNEXIT) msg="press BtnExit...";
if (Button==BTNRIGHT) msg="press BtnRight...";
if (Button==BTNLEFT) msg="press BtnLeft...";
printf1(0,LCDline[7],"%s", msg);
while (!ButtonPressed(Button, false)); while (btnhit());
// math
#define min(a,b) (a<b?a:b)
#define max(a,b) (a>b?a:b)
inline long round(float f)
if (f>=0) return (f + 0.5);
else return (f - 0.5);
inline float ArrayMedianF(float src[], int len)
float ftemp[];
ArraySort(ftemp, src, NA, NA)
return ftemp[(len-1)/2];
inline void ArrayPushF(float &src[], float _new, int len)
for (int i=len; i>0; --i) {src[i]=src[i-1];} // shift up
src[0]=_new;
// sensors
#define GYRO S2
#define COMPASS S3
long GyroHeading,
CompHeading, CompOffset,
MencHeading ;
float GyroOffset=0.0, GyroValue, GyroIntegral;
// sensor calibration
void FindGyroOffset()
float tot = 0;
for (int i=0; i<500; ++i)
tot += SensorHTGyro(GYRO, 0); // tot var is 500 gyro readings
if (!(i%100)) Beep(1760,10);
Wait(5); // Wait 5 ms (analog sensor)
PlayTone(440,100);
GyroOffset= (tot/500); // avg
task GetRotation(){
long GyroCalib=10500, temp;
float gyrodata[5];
CompHeading=CompOffset=SensorHTCompass(COMPASS);
FindGyroOffset(); // approximation of Gyro Offset
temp=0;
GyroIntegral=0;
while(1) {
GyroValue=SensorHTGyro(GYRO,0)-GyroOffset;
ArrayPushF(gyrodata, GyroValue, 5);
GyroValue= (ArrayMean(gyrodata, 0, 5));
GyroIntegral+=GyroValue;
GyroHdg=round(GyroIntegral*(360.0/GyroCalib));
if (ButtonPressed(BTNLEFT, false)) { // press BTNLEFT:
GyroIntegral=0; // reset GyroIntegral
while (btnhit()); Beep(1000,10);
// now turn robot 360°
} // then press BTNRIGHT:
if (ButtonPressed(BTNRIGHT, false)) { // reset GyroCalib after 360° turn
GyroCalib=abs(GyroIntegral);
while (GyroHdg>=360) GyroHdg-=360;
while (GyroHdg< 0) GyroHdg+=360;
CompHeading=SensorHTCompass(COMPASS);
Wait(20);
task DisplayValues() {
while (1) {
printf1(0, 56, "mot_B%6d", Menc(OUT_B));
printf1(0, 48, "mot_C%6d", Menc(OUT_C));
printf1(0, 40, "GValu%6.1f", GyroValue);
printf1(0, 32, "GIntg%6.1f", GyroIntegral);
printf1(0, 24, "GOffs%6.1f", GyroOffset);
printf1(0, 16, "MotoH%6d", MencHeading);
printf1(0, 8, "CompH%6d", CompHeading);
printf1(0, 0, "GyroH%6d", GyroHeading);
Wait(10);
task main(){
SetSensorHTGyro(GYRO);
SetSensorLowspeed(COMPASS);
start DisplayValues;
start GetRotation;
while(1);
Users browsing this forum: Ahrefs [Bot] and 1 guest
