NXC: I²C drivers for Hitechnic Tetrix motor muxer ?
Re: NXC: I²C Tetrix drivers (motor controller)?
ok,
but what about this line:
  if(!I2CBytes(link, sendMsg, msgLen, replyMsg))    return 0;
shouldn't this line be deleted as I don't want an encoder value of zero to be returned if the i2c function fails? (That would cause faulty odometric readings and calculations!)
It was an example piece of code of how to read multiple bytes and reassemble them into a long value. If you prefer to return -1 or whatever when you have a failed I2C call, by all means change the code. As it was, it wasn't suitable for your needs anyway, not without some tweaks. This came from the Dexter Industries GPS sensor driver that I wrote a while back.
uuuhhh - the server again is unbearable slow (1 minute to load "edit" or "reply"... :evil:
so you again have been faster than me....
the point is, it must return only correct values and must repeat polling as long as it needs until it gets them...
if it should be deleted, the function would look like this:
long GetTXMotorCounter(byte NXTport, byte TXmotor)
  byte devAddr;
  const byte msgLen = 4;
  byte sendMsg[];
  byte replyMsg[];
  byte encStartReg;
  devAddr = (TXmotor+2)&14;
  if ((TXmotor%2)==0) encStartReg = 0x4C;
  else encStartReg = 0x50;
  ArrayBuild(sendMsg, devAddr, encStartReg);
  // ArrayBuild(sendMsg, DGPS_I2C_ADDR, START_OF_ENCODER_REGISTER);   // Only -one- register, the first one, is requested
  while ((I2CCheckStatus(NXTport) == STAT_COMM_PENDING) && (I2CCheckStatus(NXTport) != NO_ERR)) Wait(1);
  /*  deleted  */
  // Reassemble the messages, depending on their expected size.
  return replyMsg[3] + (replyMsg[2] << 8) + (replyMsg[1] << 16) + (replyMsg[0] << 24);
:oops: ok, and link = NXTport...
if I run this program, I get File Error -1 (?????)
#define printf5( _x, _y, _format1,_format2,_format3,_format4,_format5,_value1,_value2,_value3,_value4,_value5) { \
  string sval2 = FormatNum(_format2, _value2); \
  string sval3 = FormatNum(_format3, _value3); \
  string sval4 = FormatNum(_format4, _value4); \
  string sval5 = FormatNum(_format5, _value5); \
  string s =sval1+sval2+sval3+sval4+sval5; \
  TextOut(_x, _y, s); \
#define printf2( _x, _y, _format1, _format2, _value1, _value2) { \
  string s =sval1+sval2; \
void TXMotorOn(byte NXTport, byte TXmotor, char percentage)
  byte retLen = 0;
  char modeMsg[];
  char powerMsg[];
  char IOresult;
  // addresses and registers
  modeReg = 0x44 + (TXmotor % 2)*3;
  powerReg= 0x45 + (TXmotor % 2);
  ArrayBuild(modeMsg, devAddr, modeReg, 0);
  ArrayBuild(powerMsg, devAddr, powerReg, percentage);
  // Send the first message as soon as the bus is ready
  TextOut(0,56,"M Rg md pow error");
  IOresult=I2CWrite(NXTport, retLen, modeMsg);
  if (IOresult != NO_ERR)
    { printf5(0,48-(8*TXmotor),"%d","%3d","%2d","%5d","%4d",TXmotor,modeMsg[1],modeMsg[2],powerMsg[2],IOresult);
      return;  } // for Error debug
  // Send the second message when the first one is done
  IOresult=I2CWrite(NXTport, retLen, powerMsg);
  byte devAddr;
  byte sendMsg[];
  byte replyMsg[];
  byte encStartReg;
  if (TXmotor==0) encStartReg = 0x4C;
  if (TXmotor==1) encStartReg = 0x50;
  /*  deleted  */
task main(){
  long encoder;
  SetSensorType(S1, SENSOR_TYPE_LOWSPEED);
  ResetSensor(S1);
  Wait(20);
  encoder= GetTXMotorCounter(0, 0);
  printf("%7d", encoder);
  TXMotorOn(0, 0, 50);
  TXMotorOn(0, 1, 20);
  Wait(2000);
  TXMotorOn(0, 0,  0);  // brake
  TXMotorOn(0, 1,  0);  // brake
  Wait(2000);
  TXMotorOn(0, 0, -50);
  TXMotorOn(0, 1, -20);
  Wait(2000);
  TXMotorOn(0, 0,  0); // coast
  TXMotorOn(0, 1, -128);   // brake
  Wait(2000);
  while (true);
Where's the code that does the I2CBytes() call?
is
!I2CBytes(...)
the i2C call? I simply didn't recognize this!
if I take this line in again it's working somehow...:
  TextOut(_x, _y, sval1); \
  byte retLen = 0;
  char modeMsg[];
  char powerMsg[];
  char IOresult;
  byte devAddr;
  byte sendMsg[];
  byte replyMsg[];
  byte encStartReg;
  if(!I2CBytes(NXTport, sendMsg, msgLen, replyMsg))
    return 0;
  //I2CBytes(NXTport, sendMsg, msgLen, replyMsg);
task main(){
  long encoder;
  ResetSensor(S1);
  Wait(20);
  printf1(0,8,"M1=%7d", encoder);
  Wait(2000);
  Wait(2000);
  Wait(2000);
  Wait(2000);
  Wait(2000);
  while (true);
- how must it be written if I want only valid values to be returned?
...while(!I2CBytes(NXTport, sendMsg, msgLen, replyMsg));
- and why don't you use I2cRead?
I did some experiments for a while and managed to implement a new function to reset the encoder counters:
void ResetTXMotorCounter(byte NXTport, byte TXmotor)
  byte retLen = 0;
  char modeMsg[];
  byte devAddr, modeReg;
  char IOresult;
  ArrayBuild(modeMsg, devAddr, modeReg, 3);      // 3 = reset enc value
   // Send the reset message as soon as the bus is ready
  if (IOresult != NO_ERR)   { return;  };
The good news: it works though it needs a Wait(20) to take effect.
The bad news:
the TXMotorOn function not always starts or brakes both motors - sometimes 1 of the motors simply keeps idle or keeps on running.
// program Tetrix_Motor_Driver ver. 0.14
  byte retLen = 0;
  char modeMsg[];
  char powerMsg[];
  char IOresult;
  ArrayBuild(modeMsg, devAddr, modeReg, 0);    // 0= PWM percentage mode
      return;  }
  Wait(1);
    return;  }
  Wait(1);
  byte retLen = 0;
  char modeMsg[];
  char IOresult;
  Wait(10);
  byte devAddr;
  byte sendMsg[];
  byte replyMsg[];
  byte encStartReg;
  // if(!I2CBytes(NXTport, sendMsg, msgLen, replyMsg)) return ;
  if(I2CBytes(NXTport, sendMsg, msgLen, replyMsg)) {
task showValues()  {
  long encoder0, encoder1;
  while(1) {
    encoder0= GetTXMotorCounter(0, 0);
    encoder1= GetTXMotorCounter(0, 1);
    Wait(10);
    printf1(0,8,"M1=%7d", encoder0);
    printf1(0,0,"M2=%7d", encoder1);
task main(){
  Wait(20);
  ResetSensor(S1);
  Wait(50);
  StartTask(showValues);
  while (true) {                // test loop
    Wait(2000);
    Wait(2000);
    Wait(2000);
    TXMotorOn(0, 1, -128);   // coast
    Wait(2000);
    ResetTXMotorCounter(0,0);
    ResetTXMotorCounter(0,1);
    Wait(2000);
Waits in between have no effect, the mistake stays as it is.
Any ideas how to start the motors and keep on trying until it's succesful (not break and return in case of IOresult!= NO_ERROR)?
it's really weird.
I tried and changed some lines of the code above (current version: 0.14),
but it always remains the same: in about 20 percent of all cases one of the motor commands is not executed - either if it's a run fwd, or a run rev, or a stop command (sometimes it's motor 1, sometimes motor 2, sometimes both).
Enlarging the Wait(1) to Wait(10) doesn't make it better.
EDIT: SOMETIMES an error -32 is displayed, but most of the time it's not.
This is the excerpt:
  byte retLen = 0;
  char modeMsg[];
  char powerMsg[];
  char IOresult;
      return;  }
  Wait(1);
    return;  }
  Wait(1);
Unfortunately I got no source code examples by Hitechnic since I asked them for NXC drivers more than 4 weeks ago, and so I have no idea what's actually faulty -
maybe it's the Hitechnic Tetrix controller itself?
Does anybody own such a controller and can test it by himself?
mightor wrote:I wish I had one of each of these controllers so I could test this code. It would make debugging this a lot easier.
Xander, shall I send you the controller and motors/encoders?
I am not sure I will have the time to work on it. I have a couple of new projects coming my way soon and some things I'm working on right now. I appreciate the offer of you wanting to send them to me, but I just don't have the time for it at the moment.
Users browsing this forum: Ahrefs [Bot] and 5 guests
