wishlist for NXC
Re: wishlist for NXC
will it once be possible to initialize arrays like
  int array[];
  array={0,3,5,2,9};
Removed some completely off-topic posts. Please keep this thread uncluttered. There's no lack of other threads that are more suited for banter :)
ok,
so when will the next NXC version be released?
nxtboyiii
Post by nxtboyiii »
What about a mod function?
It would return the remainder of the input float.
Like this:
 int remainder;
  remainder=mod(5.7);
  //remainder should be 0.7
Also would it be possible to fill a polygon when creating a 3d shape?
The default would be transparent, because you can see lines behind lines.
The filled would be like this:
glBeginObject();
glBegin(GL_FILL_POLYGON_WHITE);
glAddVertex(50,45,50);
//other vertexes....
glEnd();
glBegin(GL_FILL_POLYGON_BLACK);
glAddVertex(20,35,10);
glEnd();
glEndObject();
I guess what you mean is a frac function, not modulo.
Modulo is the integer division remainder, (C function symbol: "%")
what you mean are the numbers behind the decimal point.
In ANSI-C I don't know a frac function (CMIIW), but you can build it by
inline float frac(float myVal){
  return(myVal-(int)myVal); // (int) = explicite conversion - I'd wish to have it in NXC!!!
in NXC you may write
  int ibuf=myVal;  // implicite conversion
  return(myVal-ibuf);
doc-helmut wrote:in NXC you may write
  return(myVal-ibuf);
OR:
inline long trunc(float x)
    return(x);
inline float frac(float x)
    return(x - trunc(x));
OR EVEN: Because, frac() is already defined in the NXC API.
oh *surprise* - didn't expect this.
NXCBSMTC...;)
could we possibly have a
"fast i2c mode" (i2c Highspeed Mode)
the way e.g. RobotC has got?
Some i2c devices then could be possibly driven at a higher i2c speed with faster i2c calls...!
nxtboyiii
Post by nxtboyiii »
Would it be possible to add a double?
for example:
double x=78.5464325;
Adding support for a double type is not something I foresee ever happening. The existing firmware passes variables around as generic 4 byte types in a lot of places. Since a float is 4 bytes and you can store any of the smaller integer types within the 4 byte LONG used in the firmware then everything works okay. But if you tried to add support for a double which is greater than 4 bytes long then you would have to change all of that code. It would be a lot of work in the firmware and then I would have to do a lot of work in the compiler to handle a new type. Lots of work for not a whole lot of benefit.
