~ Ron, it sounds like your program is similar to mine.
My programs wait until the right number of bytes are available, by waiting until(HSInputBufferInPtr()>=BytesToReceive); Actually, I think I usually say BytesToReceive+1 (I think there is a null in there or something like that).
I just changed the setup speed from HS_BAUD_921600 to HS_BAUD_4800, and got no errors. I was sending 14 bytes each way. It also tested successfully at 9600 Baud. I tried HS_BAUD_1200 and HS_BAUD_2400, but those gave me problems (could have been that my user-code has issues).
Need some help on creating a RS485 library on NXC
Re: Need some help on creating a RS485 library on NXC
I am eagerly awaiting your results.nxtreme wrote:...I just purchased some RS485 converter chips and once they arrive (and when I finish some other projects that need finishing...) I'm going to see if I can get my NXT talking to my computer. Since I mainly want to use speeds around 4800 baud, your findings really come in handy. Thanks again!
Since your 20X2(s) is too old to work with I2C slave for the NXT, maybe you could get them talking with UART. Now, don't tell me the 20X2 version is too old for that
So am Imattallen37 wrote:I am eagerly awaiting your results.
Since your 20X2(s) is too old to work with I2C slave for the NXT, maybe you could get them talking with UART. Now, don't tell me the 20X2 version is too old for thatOr... did you get a new 20X2 with the order?
So John, I presume you look at the inbuffinptr and the inbuffoutptr on the receiver and looking the the outbuffoutptr and outbuffinptr to confirm it actually sent? Do those registers actually retrun the correct values as it is sent? That is how I wait for sending in the block and it appears to still have the issue.
Thought?
Thought?
Blog: 08milluz.wordpress.com
The latest version of the enhanced firmware has changed how the HsOutBuf.OutPtr and HsOutBuf.InPtr fields are updated. The original firmware writes the data out like this:
Notice that if you are comparing the HsOutBuf.OutPtr and the HsOutBuf.InPtr that they will have been updated before the data is completely sent - since the sending doesn't even start to occur until you call dHiSpeedSendData and it isn't actually completed for some number of milliseconds later at slower baud rates. In the enhanced firmware I originally left this function unchanged but currently it looks like this:
As you can see, I have changed the code to not update the HsOutBuf.OutPtr. The latest code leaves this field unchanged until in cCommCtrl the function dHiSpeedBytesToSend returns zero:
You can see that the IOMapComm.HsState field is now dual-purposed to hold a state value (HS_INITIALISE = 1, HS_INIT_RECEIVER, HS_SEND_DATA, HS_DISABLE, HS_ENABLE, HS_DEFAULT, HS_BYTES_REMAINING = 0x10) as well as the number of bytes remaining to be sent. Just subtract HS_BYTES_REMAINING from HsState if it is >= HS_BYTES_REMAINING.
The proper way to wait for bytes to be sent is to wait until HsState is reset back to HS_DEFAULT but with the latest enhanced firmware you should be able to wait until HsOutBuf.OutPtr is equal to HsOutBuf.InPtr.
The output buffer is always used with HsOutBuf.OutPtr starting at zero which means you write your output data to the first byte in HsOutBuf.Buf and then HsOutBuf.InPtr is set to the number of bytes you are writing. This, however, is not at all how the HsInBuf and its two pointers work. The input buffer is a circular 128 byte buffer. The next incoming byte is written to HsInBuf.Buf at the current value of HsInBuf.InPtr after which InPtr is incremented. This repeats until InPtr reaches 128 and it is reset back to zero.
HsInBuf.OutPtr is unchanged as data comes in. It should be updated in a user program to equal InPtr when you have finished reading the data from the circular input buffer. In a compiler that can call new system call functions and you have the enhanced NBC/NXC firmware on your brick then you would just use CommHSRead which will update the HsInBuf.OutPtr field for you but that function does not work right in the standard firmware. So you have to do it yourself. The CommHSRead function also copies the data correctly from the circular buffer which you have to do on your own if you can't use the enhanced NBC/NXC firmware's CommHSRead function.
In any case, I think you've got something fouled up in your code.
void cCommSendHiSpeedData(void)
VarsComm.HsModuleOutBuf.OutPtr = 0;
for (VarsComm.HsModuleOutBuf.InPtr = 0; VarsComm.HsModuleOutBuf.InPtr < IOMapComm.HsOutBuf.InPtr; VarsComm.HsModuleOutBuf.InPtr++)
VarsComm.HsModuleOutBuf.Buf[VarsComm.HsModuleOutBuf.InPtr] = IOMapComm.HsOutBuf.Buf[IOMapComm.HsOutBuf.OutPtr];
IOMapComm.HsOutBuf.OutPtr++;
dHiSpeedSendData(VarsComm.HsModuleOutBuf.Buf, (VarsComm.HsModuleOutBuf.InPtr - VarsComm.HsModuleOutBuf.OutPtr));
memcpy(VarsComm.HsModuleOutBuf.Buf, IOMapComm.HsOutBuf.Buf, IOMapComm.HsOutBuf.InPtr);
VarsComm.HsModuleOutBuf.InPtr = IOMapComm.HsOutBuf.InPtr;
dHiSpeedSendData(VarsComm.HsModuleOutBuf.Buf, VarsComm.HsModuleOutBuf.InPtr);
// IOMapComm.HsOutBuf.OutPtr = IOMapComm.HsOutBuf.InPtr;
// update the HsState if there are bytes remaining to be sent
if (IOMapComm.HsState >= HS_BYTES_REMAINING)
UWORD bts = 0;
dHiSpeedBytesToSend(&bts);
if (bts == 0)
IOMapComm.HsState = HS_DEFAULT;
IOMapComm.HsState = HS_BYTES_REMAINING + bts;
for (Tmp = 0; Tmp < NumberOfBytes; Tmp++)
IOMapComm.HsInBuf.Buf[IOMapComm.HsInBuf.InPtr] = VarsComm.HsModuleInBuf.Buf[Tmp];
IOMapComm.HsInBuf.InPtr++;
if (IOMapComm.HsInBuf.InPtr > (SIZE_OF_HSBUF - 1))
IOMapComm.HsInBuf.InPtr = 0;
VarsComm.HsModuleInBuf.Buf[Tmp] = 0;
Okay, I think I am off by 1 when updating the inbuffoutptr. Let me try that tonight and see.
