Absolute Position Regulation Tips [NXC]
schodet
Re: Absolute Position Regulation Tips [NXC]
Post by schodet »
h-g-t wrote:Just wanted to say that I finally bit the bullet and used the new motor regulation.
Thank you very much Mr Schodet! :D :D :D
Thank you :)
h-g-t wrote:Can I read one of the rotation counters to get the absolute values without cancelling the positive regulation mode?
Sure, you can use:
GetOutput (the_output, TachoLimit);
to read the current requested position.
Actually, PosRegAddAngle (the_output, 10) is equivalent to PosRegSetAngle (the_output, GetOutput (the_output, TachoLimit) + 10).
Are ther any specific commands to disable regulation?
If not, which 'normal' commands will disable it?
OK, let me rephrase the question.
If I want to reset the starting position for positive regulation -
1. Do I have to disable then re-enable regulation (if so, how)?
2. Can I just re-use the 'enable positive regulation' code and this automatically resets the starting point?
Advice appreciated as it affects how I write the program.
schodet
Post by schodet »
h-g-t wrote:OK, let me rephrase the question.
Yes, calling PosRegEnable will reset everything.
Thank you - appreciate your help.
