Actually, NXText is not a text editor. It cannot create or edit text files. Instead, it is a text file viewer and manager. Hopefully this clears up any confusion.studbrickmaster wrote: NXText NXC was a text writing program, not a messaging program.
NXText NXC?
Re: NXText NXC?
Re: NXText NXC?
THANKS!
Good to see you back, NXT Freak.
Re: NXText NXC?
NULL is now a keyword, so you can't use it as a variable. Furthermore, you must use Flatten(CONSTANT) whenever comparing a constant to a character literal. I've attached a fixed version that will hopefully work.
- NXText NXC v3.02_Fixed.zip
- (171.43 KiB) Downloaded 1107 times
Re: NXText NXC?
Is there a changelog somewhere? I haven't been updated recently either so I would like to know what have changed.
I made a file viewer a while ago which was intended to work as an example for the NXC file I/O tutorial I still haven't made... There is also an text viewer in it which uses my word-wrapping library. I'm planning to add a proper RIC file viewer (so it is easier to check the correctness of RICcreator), so if any are interested I can release it by then.
EDIT: I realize that I'm using BCC 3.3.8.9 but it is half a year old, there must surely be a newer test release? Are they still at http://bricxcc.sourceforge.net/test_releases/, or do you grab them somewhere else now?
Re: NXText NXC?
Yes, the latest test releases are there. I am using 3.3.8.10, and I believe it is the latest test version.spillerrec wrote:...EDIT: I realize that I'm using BCC 3.3.8.9 but it is half a year old, there must surely be a newer test release? Are they still at http://bricxcc.sourceforge.net/test_releases/, or do you grab them somewhere else now?
