I don't always. Normally, I have my tasks completely independent of each other (no mutexes). Normally, my tasks consist of a while(true) loop, and I don't always have a wait in the loops. IIRC, I have never experienced any issues with this method.doc-helmut wrote:...So again my question:
MUST I FOR SURE insert at least a Wait(1) to ALL task loops (also to the very fast ones) for a safe scheduling or not ?
NXC: wait(1) for safe task (scheduling) control needed?
Re: NXC: wait(1) for safe task (scheduling) control needed?
thx, matt + Xander!
- any other observations about that issue ("MUST I - or not)?
ps:- but now it's supposed to be VERY EARLY in Michigan, isn't it? ;)
You're welcome.doc-helmut wrote:thx, matt + Xander!
It is about 4:30 am, so a few hours before sunrise. My dad will probably be getting up soon. Normally, I go to bed half an hour or an hour after he gets up.
John did once say that it is a good idea to use Yield(), but he may have changed the firmware so this is not necessary anymore, and Yield() is just an "artifact" from the stone age of NXC
(Currently, we're in the extremely high-tech middle ages.
my question was not about "a good idea" but about a definite answer to "unnecessarily needed or not"
Probably not needed with the new EFs, but we'll need John Hansen to confirm this.doc-helmut wrote:my question was not about "a good idea" but about a definite answer to "unnecessarily needed or not"
well, "probably" is not the answer that I was looking for...
I don't think it is. Why don't you just try an example program, and see for yourself? Write a program that uses several tasks at the same time, and don't use waits. See what happens. I don't think the NXT will explode if it doesn't work.
I can't test it in the environment in which I actually need to have it - in my case it's the 14-20 task subsumption program. I will never know if 1 ppm of the BT communications and/or I2C sensor readings and/or priority calculations are faulty or not if I sacrifice all the Wait(1) in all tasks.
But Xander's reply appears to me to be the most confident one so far.
Well, that is why I recommended a test program. Often, I write a program just to test a single function or concept.
