NXC: PCF8574 read 8 values all at once ?
Re: NXC: PCF8574 read 8 values all at once ?
ok, with the following it works :
#define BitRead(_Value, _Bit) !(0x01 & (_Value >> (_Bit - 1 ) )) // 1...8 instead of 0...7
:ugeek:
int PCF8574ReadPins(byte port, byte address){
  byte cnt = 2;
  byte I2CMsg[];
  byte inbuf[];
  byte nByteReady = 0;
  int  result = -1;
  ArrayBuild(I2CMsg, address);
  while (I2CStatus(port, nByteReady) == STAT_COMM_PENDING){
    Yield();
  if (I2CBytes(port, I2CMsg, cnt, inbuf)) {
    result = inbuf[1];
  if(result==-1){
     TextOut(0, LCD_LINE1, "Error: Check the");
     TextOut(0, LCD_LINE2, "   connection!");
     Wait(500);
  return result;
task main() {
  byte PCF8574array[9]; // just to have slots 1...8 to access
  byte PCF8574port=S4, PCF8574addr=0x4E, result;
  SetSensorLowspeed(S4);
  while(true) {
    result=PCF8574ReadPins(PCF8574port, PCF8574addr);  // poll the PCF byte once
    for (char i=1; i<9; ++i) {
      PCF8574array[i]= BitRead(result, i);             // bit read the PCF byte
      NumOut( 0, 56-(8*i), i);
      NumOut(18, 56-(8*i), PCF8574array[i]);
    Wait(5);
thanks, Matt!
:mrgreen:
If the sensor is pressed, the IO state should be 0. The touch sensor pulls the line low when pressed, and when not pressed, the internal pullup of the PCF8574 IO pulls the line back high.
Inverting the value like you did is a good way to fix the "problem". Note however that the ! symbol means logic NOT, and the ~ symbol means bit NOT. It's not common practice to use ! when dealing with bits/data, rather than logic. Along the lines of more common programming practice, I would have done something like this instead:
#define BitRead(_Value, _Bit) (0x01 & ((~_Value) >> (_Bit - 1 ) )) // 1...8 instead of 0...7
I'm glad it's working for you ;)
I admittedly don't understand the "level pull" thing because I don't understand the electronical side
- but -
yes, thanx, works quite as well! :)
- and insanely quick! :D
Users browsing this forum: Semrush [Bot] and 41 guests
