I'm baaaaaack! (With a new graphics project)
stryker001
Re: I'm baaaaaack! (With a new graphics project)
Post by stryker001 »
How 'bout all of it? I still can't find the issue but I'll go back over it better this time.
The basics of this code is this: moving imaginary points around, and rendering lines between them.
By turning Motor B, I can adjust how many points there are, between 1 and 16.
By turning Motor A, I (should) be able to adjust the speed of the points. I did this by writing speed = speed * (motor reading) with the motor reading always a number above zero, or else they wouldn't move at all. (I didn't have the +1 when I first wrote the code and they wouldn't move at all, but after adding the +1 they still don't move.) I just commented that section out and instead changed it (at the bottom) so that adjusting the motor adjusts the time between each frame.
Also, due to some crazy bug I haven't worked out, when there's less than 4 lines being drawn, it moves really, really fast.
task main(){
  int x1 = (Random(99));
  int y1 = Random(63);   // Set the first point anywhere on the screen
  int x1_vel = (Random(3) + 1);// and give it two random velocities.
  int y1_vel = (Random(3) + 1);
  int x2 = Random(99);
  int y2 = Random(63);   // Same, but for the second point.
  int x2_vel = (Random(3) + 1);
  int y2_vel = (Random(3) + 1);
  int x3 = Random(99);
  int y3 = Random(63);   // 3rd point, etc.
  int x3_vel = (Random(3) + 1);
  int y3_vel = (Random(3) + 1);
  int x4 = Random(99);
  int y4 = Random(63);
  int x4_vel = (Random(3) + 1);
  int y4_vel = (Random(3) + 1);
  int x5 = Random(99);
  int y5 = Random(63);
  int x5_vel = (Random(3) + 1);
  int y5_vel = (Random(3) + 1);
  int x6 = Random(99);
  int y6 = Random(63);
  int x6_vel = (Random(3) + 1);
  int y6_vel = (Random(3) + 1);
  int x7 = Random(99);
  int y7 = Random(63);
  int x7_vel = (Random(3) + 1);
  int y7_vel = (Random(3) + 1);
  int x8 = Random(99);
  int y8 = Random(63);
  int x8_vel = (Random(3) + 1);
  int y8_vel = (Random(3) + 1);
  int x9 = Random(99);
  int y9 = Random(63);
  int x9_vel = (Random(3) + 1);
  int y9_vel = (Random(3) + 1);
  int x10 = Random(99);
  int y10 = Random(63);
  int x10_vel = (Random(3) + 1);
  int y10_vel = (Random(3) + 1);
  int x11 = Random(99);
  int y11 = Random(63);
  int x11_vel = (Random(3) + 1);
  int y11_vel = (Random(3) + 1);
  int x12 = Random(99);
  int y12 = Random(63);
  int x12_vel = (Random(3) + 1);
  int y12_vel = (Random(3) + 1);
  int x13 = Random(99);
  int y13 = Random(63);
  int x13_vel = (Random(3) + 1);
  int y13_vel = (Random(3) + 1);
  int x14 = Random(99);
  int y14 = Random(63);
  int x14_vel = (Random(3) + 1);
  int y14_vel = (Random(3) + 1);
  int x15 = Random(99);
  int y15 = Random(63);
  int x15_vel = (Random(3) + 1);
  int y15_vel = (Random(3) + 1);
  int x16 = Random(99);
  int y16= Random(63);
  int x16_vel = (Random(3) + 1);
  int y16_vel = (Random(3) + 1);
  while (true){
/*    int x1_vel = x1_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int y1_vel = y1_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int x2_vel = x2_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int y2_vel = y2_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int x3_vel = x3_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int y3_vel = y3_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int x4_vel = x4_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int y4_vel = y4_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int x5_vel = x5_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int y5_vel = y5_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int x6_vel = x6_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int y6_vel = y6_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int x7_vel = x7_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int y7_vel = y7_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int x8_vel = x8_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int y8_vel = y8_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int x9_vel = x9_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int y9_vel = y9_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int x10_vel = x10_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int y10_vel = y10_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int x11_vel = x11_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int y11_vel = y11_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int x12_vel = x12_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int y12_vel = y12_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int x13_vel = x13_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int y13_vel = y13_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int x14_vel = x14_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int y14_vel = y14_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int x15_vel = x15_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int y15_vel = y15_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int x16_vel = x16_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    int y16_vel = y16_vel * (abs((MotorTachoCount(OUT_A)/10)) + 1);
    x1 = x1 + x1_vel;
    x2 = x2 + x2_vel;
    x3 = x3 + x3_vel;
    x4 = x4 + x4_vel;
    x5 = x5 + x5_vel;
    x6 = x6 + x6_vel;
    x7 = x7 + x7_vel;
    x8 = x8 + x8_vel;
    x9 = x9 + x9_vel;
    x10 = x10 + x10_vel;
    x11 = x11 + x11_vel;
    x12 = x12 + x12_vel;
    x13 = x13 + x13_vel;
    x14 = x14 + x14_vel;
    x15 = x15 + x15_vel;
    x16 = x16 + x16_vel;
    y1 = y1 + y1_vel;
    y2 = y2 + y2_vel;
    y3 = y3 + y3_vel;
    y4 = y4 + y4_vel;
    y5 = y5 + x5_vel;
    y6 = y6 + y6_vel;
    y7 = y7 + y7_vel;
    y8 = y8 + y8_vel;
    y9 = y9 + y9_vel;
    y10 = y10 + y10_vel;
    y11 = y11 + y11_vel;
    y12 = y12 + y12_vel;
    y13 = y13 + y13_vel;
    y14 = y14 + y14_vel;
    y15 = y15 + y15_vel;
    y16 = y16 + y16_vel;
    if (x1 >99){
      x1 = 99;
      x1_vel = (-x1_vel);
    if (x1 <0){
      x1 = 0;
      x1_vel = (-x1_vel);
    if (y1 >63){
      y1 = 63;
      y1_vel = (-y1_vel);
    if (y1 <0){
      y1 = 0;
      y1_vel = (-y1_vel);
    if (x2 >99){
      x2 = 99;
      x2_vel = (-x2_vel);
    if (x2 <0){
      x2 = 0;
      x2_vel = (-x2_vel);
    if (y2 >63){
      y2 = 63;
      y2_vel = (-y2_vel);
    if (y2 <0){
      y2 = 0;
      y2_vel = (-y2_vel);
    if (x3 >99){
      x3 = 99;
      x3_vel = (-x3_vel);
    if (x3 <0){
      x3 = 0;
      x3_vel = (-x3_vel);
    if (y3 >63){
      y3 = 63;
      y3_vel = (-y3_vel);
    if (y3 <0){
      y3 = 0;
      y3_vel = (-y3_vel);
    if (x4 >99){
      x4 = 99;
      x4_vel = (-x4_vel);
    if (x4 <0){
      x4 = 0;
      x4_vel = (-x4_vel);
    if (y4 >63){
      y4 = 63;
      y4_vel = (-y4_vel);
    if (y4 <0){
      y4 = 0;
      y4_vel = (-y4_vel);
    if (x5 >99){
      x5 = 99;
      x5_vel = (-x5_vel);
    if (x5 <0){
      x5 = 0;
      x5_vel = (-x5_vel);
    if (y5 >63){
      y5 = 63;
      y5_vel = (-y5_vel);
    if (y5 <0){
      y5 = 0;
      y5_vel = (-y5_vel);
    if (x6 >99){
      x6 = 99;
      x6_vel = (-x6_vel);
    if (x6 <0){
      x6 = 0;
      x6_vel = (-x6_vel);
    if (y6 >63){
      y6 = 63;
      y6_vel = (-y6_vel);
    if (y6 <0){
      y6 = 0;
      y6_vel = (-y6_vel);
    if (x7 >99){
      x7 = 99;
      x7_vel = (-x7_vel);
    if (x7 <0){
      x7 = 0;
      x7_vel = (-x7_vel);
    if (y7 >63){
      y7 = 63;
      y7_vel = (-y7_vel);
    if (y7 <0){
      y7 = 0;
      y7_vel = (-y7_vel);
    if (x8 >99){
      x8 = 99;
      x8_vel = (-x8_vel);
    if (x8 <0){
      x8 = 0;
      x8_vel = (-x8_vel);
    if (y8 >63){
      y8 = 63;
      y8_vel = (-y8_vel);
    if (y8 <0){
      y8 = 0;
      y8_vel = (-y8_vel);
    if (x9 >99){
      x9 = 99;
      x9_vel = (-x9_vel);
    if (x9 <0){
      x9 = 0;
      x9_vel = (-x9_vel);
    if (y9 >63){
      y9 = 63;
      y9_vel = (-y9_vel);
    if (y9 <0){
      y9 = 0;
      y9_vel = (-y9_vel);
    if (x10 >99){
      x10 = 99;
      x10_vel = (-x10_vel);
    if (x10 <0){
      x10 = 0;
    if (y10 >63){
      y10 = 63;
      y10_vel = (-y10_vel);
    if (y10 <0){
      y10 = 0;
    if (x11 >99){
      x11 = 99;
      x11_vel = (-x11_vel);
    if (x11 <0){
      x11 = 0;
    if (y11 >63){
      y11 = 63;
      y11_vel = (-y11_vel);
    if (y11 <0){
      y11 = 0;
    if (x12 >99){
      x12 = 99;
      x12_vel = (-x12_vel);
    if (x12 <0){
      x12 = 0;
    if (y12 >63){
      y12 = 63;
      y12_vel = (-y12_vel);
    if (y12 <0){
      y12 = 0;
    if (x13 >99){
      x13 = 99;
      x13_vel = (-x13_vel);
    if (x13 <0){
      x13 = 0;
    if (y13 >63){
      y13 = 63;
      y13_vel = (-y13_vel);
    if (y13 <0){
      y13 = 0;
    if (x14 >99){
      x14 = 99;
      x14_vel = (-x14_vel);
    if (x14 <0){
      x14 = 0;
    if (y14 >63){
      y14 = 63;
      y14_vel = (-y14_vel);
    if (y14 <0){
      y14 = 0;
    if (x15 >99){
      x15 = 99;
      x15_vel = (-x15_vel);
    if (x15 <0){
      x15 = 0;
    if (y15 >63){
      y15 = 63;
      y15_vel = (-y15_vel);
    if (y15 <0){
      y15 = 0;
    if (x16 >99){
      x16 = 99;
      x16_vel = (-x16_vel);
    if (x16 <0){
      x16 = 0;
    if (y16 >63){
      y16 = 63;
      y16_vel = (-y16_vel);
    if (y16 <0){
      y16 = 0;
    NumOut(1, 1, (MotorTachoCount(OUT_B)/10), 0);
    NumOut(1, 9, (abs((MotorTachoCount(OUT_A)/10)) + 1), 0);
    if ((MotorTachoCount(OUT_B)/10) > 0){
      if (MotorTachoCount(OUT_B)/10 < 2){
        LineOut(x1, y1, x1, y1, 0);
    if ((MotorTachoCount(OUT_B)/10) > 1){
      if (MotorTachoCount(OUT_B)/10 < 3){
        LineOut(x1, y1, x2, y2, 0);
        LineOut(x2, y2, x1, y1, 0);
    if ((MotorTachoCount(OUT_B)/10) > 2){
      if (MotorTachoCount(OUT_B)/10 < 4){
        LineOut(x2, y2, x3, y3, 0);
        LineOut(x3, y3, x1, y1, 0);
    if ((MotorTachoCount(OUT_B)/10) > 3){
      if ((MotorTachoCount(OUT_B)/10) < 5){
        LineOut(x3, y3, x4, y4, 0);
        LineOut(x4, y4, x1, y1, 0);
    if ((MotorTachoCount(OUT_B)/10) > 4){
      if ((MotorTachoCount(OUT_B)/10) < 6){
        LineOut(x4, y4, x5, y5, 0);
        LineOut(x5, y5, x1, y1, 0);
    if ((MotorTachoCount(OUT_B)/10) > 5){
      if ((MotorTachoCount(OUT_B)/10) < 7){
        LineOut(x5, y5, x6, y6, 0);
        LineOut(x6, y6, x1, y1, 0);
    if ((MotorTachoCount(OUT_B)/10) > 6){
      if ((MotorTachoCount(OUT_B)/10) < 8){
        LineOut(x6, y6, x7, y7, 0);
        LineOut(x7, y7, x1, y1, 0);
    if ((MotorTachoCount(OUT_B)/10) > 7){
      if ((MotorTachoCount(OUT_B)/10) < 9){
        LineOut(x7, y7, x8, y8, 0);
        LineOut(x8, y8, x1, y1, 0);
    if ((MotorTachoCount(OUT_B)/10) > 8){
      if ((MotorTachoCount(OUT_B)/10) < 10){
        LineOut(x8, y8, x9, y9, 0);
        LineOut(x9, y9, x1, y1, 0);
    if ((MotorTachoCount(OUT_B)/10) > 9){
      if ((MotorTachoCount(OUT_B)/10) < 11){
        LineOut(x9, y9, x10, y10, 0);
        LineOut(x10, y10, x1, y1, 0);
    if ((MotorTachoCount(OUT_B)/10) > 10){
      if ((MotorTachoCount(OUT_B)/10) < 12){
        LineOut(x10, y10, x11, y11, 0);
        LineOut(x11, y11, x1, y1, 0);
    if ((MotorTachoCount(OUT_B)/10) > 11){
      if ((MotorTachoCount(OUT_B)/10) < 13){
        LineOut(x11, y11, x12, y12, 0);
        LineOut(x12, y12, x1, y1, 0);
    if ((MotorTachoCount(OUT_B)/10) > 12){
      if ((MotorTachoCount(OUT_B)/10) < 14){
        LineOut(x12, y12, x13, y13, 0);
        LineOut(x13, y13, x1, y1, 0);
    if ((MotorTachoCount(OUT_B)/10) > 13){
      if ((MotorTachoCount(OUT_B)/10) < 15){
        LineOut(x13, y13, x14, y14, 0);
        LineOut(x14, y14, x1, y1, 0);
    if ((MotorTachoCount(OUT_B)/10) > 14){
      if ((MotorTachoCount(OUT_B)/10) < 16){
        LineOut(x14, y14, x15, y15, 0);
        LineOut(x15, y15, x1, y1, 0);
    if ((MotorTachoCount(OUT_B)/10) > 15){
        LineOut(x15, y15, x16, y16, 0);
        LineOut(x16, y16, x1, y1, 0);
    Wait((abs((MotorTachoCount(OUT_A)/5)) + 1));
stryker001
when the video finishes uploading, it will be here:
http://youtu.be/cMHWmtzmxAI
EDIT
I forgot to mention, the wait value is on the first line, but it's half of what the value actually is.
The number of rendered lines is on the second line. Obviously it only does up to 16 lines because that's all I programmed in it.
