NXC: functions with different numbers of parameters?
Re: NXC: functions with different numbers of parameters?
spillerec wrote:but it seems like it is the compiler which easily messes up with scientific notification.
yes, indeed, it seems to be a compiler bug, cause I also tried it by
// #define FLT_MAX 1E37
float FLT_MAX=1E37;
float max(float f1, float f2, float f3 = -FLT_MAX, float f4 = -FLT_MAX, float f5 = -FLT_MAX) {
  float flarr[5], f;
  flarr[0]=f1; flarr[1]=f2; flarr[2]=f3; flarr[3]=f4; flarr[4]=f5;
  f=ArrayMax( flarr, 0, 5 );
  return f;
task main() {
  NumOut(0,8, max(7.1, 12.4, 5.9, 18.6));   // if it works, then NumOut does not display floats!
  //NumOut(0,0, max(7.1, 12.4, 5.9, 1E+9));   // compiler error
  for(;;);
with a similar error msg.
# Error: Invalid floating point operation
File "c:\Temp\temp.nxc" ; line 5
# FLT_MAX float 9.99999999999999954E36
# Error: Error parsing expression: FLT_MAX |
File "c:\Temp\temp.nxc" ; line 14
2 errors during compilation
it's not just always like the max thing passing the same vatiable types, what actually my goal is - it's more also having different numbers of parameters of different types, like how it is possible in the TextOut example:
TextOut( char x, char y, string s(, optional: int textstyle));
NXC does not currently support scientific notation for numeric constants.
ok, but this also doesn't work - what's wrong with this?
#define FLT_MAX 10000000000000000000000000000000000000
  float flarr[5];
  return ArrayMax( flarr, 0, 5 );
task main() {
  NumOut(0,8, max(7.1, 12.4, 5.9, 18.6));   // NumOut does not display floats, just ints!
  for(;;);
# Error: Invalid parameter syntax with default values
# float max(float f1, float f2, float f3 = -9.99999999999999954E36, f
# Error: Not valid for a prototype
File "c:\Temp\temp.nxc" ; line 6
# f
# Error: Undefined Identifier f4
File "c:\Temp\temp.nxc" ; line 7
# flarr[0]=f1; flarr[1]=f2; flarr[2]=f3; flarr[3]=f4;
# Error: Undefined Identifier f5
# flarr[0]=f1; flarr[1]=f2; flarr[2]=f3; flarr[3]=f4; flarr[4]=f5;
File "c:\Temp\temp.nxc" ; line 9
# r
# Error: Too many arguments
# NumOut(0,8, max(7.1, 12.4, 5.9, 18.6)
# Error: ")" expected
# Error: ')' expected
# Error: ';' expected
# NumOut(0,8, max(7.1, 12.4, 5.9, 18.6))
It looks like the preprocessor is causing your very large constant to be represented as number in exponential notation which the NXC compiler does not currently support.
Does this work?
float max(float f1, float f2, float f3 = -FLT_MAX, float f4 = -10000000000000000000000000000000000000, float f5 = -10000000000000000000000000000000000000) {
  float flarr[5];
unfortunately, no
float max(float f1, float f2, float f3 = -10000000000000000000000000000000000000,
  float flarr[5];
task main() {
  NumOut(0,8, max(7.1, 12.4, 5.9, 18.6));   // if it incidentally works, then  NumOut does not display floats!
  for(;;);
# mov __max_7qG2_f5_7qG2_000, -10000000000000000000000000000000000000
1 errors during compilation
is there any reason why assigning of large floating point numbers is impossible at all (either which notation) ?
linusa
Post by linusa »
-10000000000000000000000000000000000000 is of type integer, maybe try -10000000000000000000000000000000000000.0 or -10000000000000000000000000000000000000.0f
float f3 = -10000000000000000000000000000000000000.0f is invalid syntax,
if I try
//#define FLT_MAX 1E37
//#define FLT_MAX 10000000000000000000000000000000000000
float max(float f1, float f2, float f3 = -10000000000000000000000000000000000000.0,
                              float f4 = -10000000000000000000000000000000000000.0,
                              float f5 = -10000000000000000000000000000000000000.0) {
  float flarr[5];
task main() {
  for(;;);
again the same error occurs:
File "G:\Akten\Programmierung\NXC\Test\multparamstest.nxc" ; line 16
# mov __max_7qG2_f5_7qG2_000, -10000000000000000000000000000000000000.0
peculiar:
formerly, the error msg refers to the system temp directory -
now the error refers to my working directory...
Yesterday I uploaded a new test release which should fix most of the problems Doc was experiencing with floating point constants/exponential notation.
