a software problem
Re: a software problem
The sequence beam is broken between the random block and the switch. Click on the switch block, drag it away from its current location and then drag it back.
ok thankyou, I didn't see this broken beam. I don't know if I could see it or not.
Thankyou
Thankyou
Hi, I have another problem.
I know that when you want to make two programmes work togheter you put them in only one programme and in different directions from the start point/main point
but I am trying it and It doesn't work, I want to do a separated switch (it only works when the touch sensor takes part) in the program that when it ends, continue doing the main program.
How can I do it?
How can I do it?
