Bluetooth troubles in NXT-G
zemata
Post by zemata »
Running windows 7, just bought this dongle http://www.amazon.com/Bluetooth-USB-Mic ... 803&sr=8-1
I got the NXT brick to connect to my PC. The icon on the brick is <> and my bluetooth program sees it connected BUT NXT-G cannot find my brick when I click scan. I've restarted the program, the brick, deleted all the connections and nothing. Help!
jojoguy14
Re: Bluetooth troubles in NXT-G
Post by jojoguy14 »
Try turning on the Bluetooth on the NXT brick itself. When you first turn on the NXT, go to the left until you find the bluetooth icon. "Click" that, and it should only have one option.
Hope this helps!
Known as jojoguy10
Perhaps you should check that you have the latest Lego Fantom driver, available at
http://us.mindstorms.lego.com/en-us/sup ... river.aspx
zemata
Post by zemata »
Yeah none of this helps. Of course I have bluetooth turned on on the NXT brick and the drivers you linked me to are firmware updates for the brick it says.
Post by hassenplug »
zemata wrote:Running windows 7, just bought this dongle http://www.amazon.com/Bluetooth-USB-Mic ... 803&sr=8-1
I have a bunch of dongles like this. The ONLY ones that work well are the ones with the CSR chipset. (see here:http://mindstorms.lego.com/en-us/bluetooth/default.aspx under dongles).
I would recommend searching out one of those. It would be your best use of time and money.
zemata
Post by zemata »
Im having a hard time finding a CSR dongle online. Could you point me towards one that you know works, or one that works and has a high MB per second rate? Preferrably from amazon as I plan to order ore servos there.
zemata
Post by zemata »
The second link is the exact one that I bought. Are there specific drivers I need to have it work well with mindstorms? This is so frustrating!
zemata wrote:Yeah none of this helps. Of course I have bluetooth turned on on the NXT brick and the drivers you linked me to are firmware updates for the brick it says.
zemata
Post by zemata »
Ok guys thanks for the advice. Just popping in one last time to say it's working now. I can get into my brick wirelessly from NXT-G :D. My problem was after I installed the latest drivers, I didn't try connecting from NXT-G, but I kept trying to connect from the brick!
Users browsing this forum: Semrush [Bot] and 181 guests
