I don't know the "best" way, but I would use SENSOR_1. You also need to declare the variable. I assume you want a 16-bit signed value, so you should also add "int temp;". I would also not display the number 1 pixel from bottom and left. I would use LCD_LINE1, 0. You also need to clear the screen from previous values. I would use ClearScreen(), and to slow it down so it doesn't flicker a lot I would add a 50ms wait. I would make the program like this:
int temp;
  SetSensor(S1, SENSOR_CELSIUS);
  while(true)
    temp = SENSOR_1;
    ClearScreen();
    NumOut(LCD_LINE1, 0, temp);
    Wait(50);
And if you only want to display the temperature, you don't even need variable temp.
Here is how I would do it simply:
  while(true)
    ClearScreen();
    NumOut(LCD_LINE1, 0, SENSOR_1);
    Wait(50);
Or with a more fancy appearance:
  while(true)
    string temp = NumToStr(SENSOR_1) + " C";
    ClearScreen();
    TextOut(LCD_LINE1, 0, temp);
    Wait(50);
Note however, that I didn't test run any of these programs.
