Is there a way to set a bunch of things to the screen and then draw them all at the same time with a function?
If not, can someone tell me how? I am doing this so things on the screen won't flicker.
[NXC] Draw using flags
Re: [NXC] Draw using flags
That's basically what I asked for a while ago. What I want is a dual screen buffer, so you can write to one, and then display it while you are writing to the other one. You would keep switching so everything would display in sync.
Relevant post(s) here.
Yeah... I know.
But is there at least some way to stop screen flicker?
Try to look at the SetDisplayFlags() function. It seemed to work fine for me, but it was just a quick test and my code didn't cause that much flicker anyway...
