My Block equivalent in NXC
I am just starting to learn NXC, and I was wondering if there was an equivalent for NXT-G My Blocks in NXC
Re: My Block equivalent in NXC
'My Blocks' in NXC probably have more functionality than NXT-G My Blocks.
They're called subroutines/procedures and functions.
Subroutines:
Guess what that code does?
I recommend learning C++ (or at least, the C parts of it) from this tutorial. It's explained very well for a beginner.
Subroutines:
void MyVoid()
TextOut(0, 0, "Hello MyVoid!");
Wait(2000);
MyVoid();
Yes, but is there any way to save a section of code that you can call on in any of your programs?muntoo wrote:'My Blocks' in NXC probably have more functionality than NXT-G My Blocks.![]()
Yes there is. Make a library.
What I do, is have a folder that contains all my libraries, and include that path with the compiler settings. If I want to use one of libraries, all I have to do is #include it, and all the functions are available.
Ah, I get what you're talking about now. Use #includes.
A demonstration:
main.nxc
myblocks.nxc
Just put #include "myblocks.nxc" in all of your programs from now on. (And don't forget to put "myblocks.nxc" in the same folder as each of your programs.)
A better way would be to create a library, as Matt (who ninja'd me) suggested. That way, your "myblocks.nxc" code won't have to be compiled unnecessarily for one function/"block" you want to use out of a few unrelated hundred.
A demonstration:
main.nxc
HelloWorld();
void HelloWorld()
TextOut(0, 0, "Hello, World!", 0);
Wait(2000);
Muntoo, I think you missed my point. You do not have to save the libraries (or "myblocks.nxc") in the same directory... you can make the compiler look in an additional directory (where all the libraries or whatever else is located). It keeps me from have a zillion duplicates all over the place. It also means I only have to modify it in one place, and everything get modified.muntoo wrote:...Just put #include "myblocks.nxc" in all of your programs from now on. (And don't forget to put "myblocks.nxc" in the same folder as each of your programs.)
How do you do that?mattallen37 wrote: ... you can make the compiler look in an additional directory (where all the libraries or whatever else is located).
Also is there any way to pass parameters into and out of voids? (Like data wires in NXT-G?)
Like this:See how I did that? In that simple (example) function, I passed three ints into it (int value, int min, int max), and it send one back (int &end_value). The "&" means that it is an "output wire".
However, for that specific function, I would probably normally use something more like this:Instead of calling the function like this "SetLimits(value, min, max, result);", you would call it like this "NumOut(0, LCD_LINE1, SetLimits(value, min, max));". Because it is a "int" function, it has a numerical value (chosen by the "return" command).
Also, you are not limited to passing ints in and out of functions. You can use bool, char, byte, int, Uint, long, Ulong, array, string...
Yes you can pass values in and out of a void function. Here is an example:Code: Select all
void SetLimits(int value, int min, int max, int &result){
if (value>max)value=max;
if (value<min)value=min;
result=value;
int SetLimits(int value, int min, int max){
return value;
Thanks!
Users browsing this forum: No registered users and 36 guests
