Display Time Block Bug
I have noticed a bug with the Display Number/Display Time blocks from Team Hassenplug. If you wire a timer into these blocks and place it in a loop, when the timer reaches 33 seconds, instead of displaying 0:33:00 it displays 0:-31:00 and continues counting down in minus until it reaches 0:00:00 and then it starts happening all over again. I have attached a video made with NeXT Screen and Hyper Cam 2, and the test program. Does anyone else experience this bug?
Display Time Bug.zip
(Because the attachment file will not upload, follow the above link to download it from the Mindboards Repository)
Re: Display Time/Number blocks bug
Where is it?studbrickmaster wrote:...I have attached a video ... and the test program...
It was not uploading with the message. I do not know if it is an issue of size (2.1MB) or just phpBB. I have uploaded the file to here.mattallen37 wrote:Where is it?studbrickmaster wrote:...I have attached a video ... and the test program...
Re: Display Time Block Bug
Can't you just use the Capture AVI feature in NXTScreenstudbrickmaster wrote:I have attached a video made with NeXT Screen and Hyper Cam 2, and the test program.
What capture AVI feature?timpattinson wrote:Can't you just use the Capture AVI feature in NXTScreenstudbrickmaster wrote:I have attached a video made with NeXT Screen and Hyper Cam 2, and the test program.
studbrickmaster wrote:What capture AVI feature?timpattinson wrote:Can't you just use the Capture AVI feature in NXTScreenstudbrickmaster wrote:I have attached a video made with NeXT Screen and Hyper Cam 2, and the test program.
Try upgrading nxtscreen/bricxcc
Which one are you using.
There are 2 links to the file - who cares what he used to create it?
It does that because the value is a 16-bit signed value. Because time can't be negative, the block should use either an unsigned 16-bit variable (up to ~65,000), or an unsigned 32-bit variable (up to >4,000,000,000).
