Yaw Rate Sensor
ozzie88
Yaw Rate Sensor
Post by ozzie88 »
Hi everyone,
I'd like to use the NXT for a new school project. I need to measure yaw rate to control the system.
Does anyone know if there is a yaw rate sensor available for the NXT, or how to measure using standard sensor hardware?
I appreciate your responses!
rghansen
Re: Yaw Rate Sensor
Post by rghansen »
This should do the job for you: https://www.hitechnic.com/cgi-bin/comme ... ey=NGY1044
You can also order it (or something very similar) directly from lego.
Does anyone know if the Lego and the Hitechnic gyros are the same?
jojoguy14
Re: Yaw Rate Sensor
Post by jojoguy14 »
rghansen wrote: Does anyone know if the Lego and the Hitechnic gyros are the same?
Yes they are. HT is the creator, LEGO is just another seller.
Known as jojoguy10
ozzie88
Re: Yaw Rate Sensor
Post by ozzie88 »
Great. Thank you!
aswin0
Re: Yaw Rate Sensor
Post by aswin0 »
I write some blogs about this sensor and how to use it. The most popular is this one about offset and drift. You might find it useful.
ozzie88
Re: Yaw Rate Sensor
Post by ozzie88 »
Thanks for the feedback. Good info.
