Drawing clear solid rectangles in NXC
How do you draw clear solid rectangles in NXC? I know how to draw clear rectangles, OR solid rectangles, but how do you do clear solid rectangles?
Re: Drawing clear solid rectangles in NXC
Clear solid? What do you mean exactly? Can you draw it in ms paint or something similar so we know what it is supposed to look like?
How about I post a program that draws in white.You can draw solid shapes using the DRAW_OPT_FILL_SHAPE macro. You can draw white on black using the DRAW_OPT_CLEAR macro. I want to draw solid white on a black background.
RectOut(0, 0, 100, 64, DRAW_OPT_FILL_SHAPE); //Blacks out a solid rectangle
RectOut(25, 16, 50, 32, DRAW_OPT_CLEAR); //Whites out a normal rectangle
RectOut(25, 24, 50, 32, DRAW_OPT_CLEAR); //Whites out a normal rectangle
RectOut(25, 8, 50, 32, DRAW_OPT_CLEAR); //Whites out a normal rectangle
RectOut(13, 16, 50, 32, DRAW_OPT_CLEAR); //Whites out a normal rectangle
RectOut(37, 16, 50, 32, DRAW_OPT_CLEAR); //Whites out a normal rectangle
while(true);
Never mind, I just figured it out. The two macros have the values of 32 and 4, so I just tried combining them using the value 36, and it works. Thanks anyhow.
That "standard" way to do it is:mattallen37 wrote:Never mind, I just figured it out. The two macros have the values of 32 and 4, so I just tried combining them using the value 36, and it works. Thanks anyhow.
int There = 51, AndBackAgain = 52; // This is how little folk code
int ToTheFuture = 99; // Mad scientists code this
int AndLOTRpwnsBTTF = true; // Geniuses only
RectOut(There, AndBackAgain, ToTheFuture, AndLOTRpwnsBTTF, DRAW_OPT_CLEAR | DRAW_OPT_FILL_SHAPE);
Ok. I would think though that you would do something like DRAW_OPT_CLEAR + DRAW_OPT_FILL_SHAPE instead of DRAW_OPT_CLEAR | DRAW_OPT_FILL_SHAPE for the last parameter. Using the "+" obviously adds the constants (macros), thus still getting a sum of 36 (which is the value I am using). What does the single "|" do?
In Standard C and NXC, '|' is bit-wise OR. Since the drawing options are all powers of two (a common way to implement boolean options), '+' and '|' have the same effect in this case.mattallen37 wrote:Ok. I would think though that you would do something like DRAW_OPT_CLEAR + DRAW_OPT_FILL_SHAPE instead of DRAW_OPT_CLEAR | DRAW_OPT_FILL_SHAPE for the last parameter. Using the "+" obviously adds the constants (macros), thus still getting a sum of 36 (which is the value I am using). What does the single "|" do?
Regards, Morton
You sound like Linusmattallen37 wrote:Ok. I would think though that you would do something like DRAW_OPT_CLEAR + DRAW_OPT_FILL_SHAPE instead of DRAW_OPT_CLEAR | DRAW_OPT_FILL_SHAPE for the last parameter. Using the "+" obviously adds the constants (macros), thus still getting a sum of 36 (which is the value I am using). What does the single "|" do?
For flags, you use Bitwise-OR ("|") *. For other stuff (I don't know what exactly), you use adding, or whatever you use. My point is... OK, hold on, I've asked it on programmers.stackexchange.com HERE.
Someone over here is using the Bitwise-OR method.
*That looks strangely like a messed up smiley.
Ah yes, I see it now. The third and sixth least significant bits (0x04 and 0x20) are the ones used here. Thanks for the clarification/explanation.
Users browsing this forum: No registered users and 36 guests
