Some useful NXC guides -
http://www.engineering.uiowa.edu/~cie/L ... torial.pdf
http://bricxcc.sourceforge.net/nbc/nxcdoc/
Did you get your program working yet?
motor problems
Re: motor problems
ninjaman1138
Re: motor problems
hello
thanks for your help, im going to use the rotatemotor command instead as that does exactly what is want without the extra fuss.
I am having a problem though with a line follower program. I can get the robot to follow the line and turn but it wont turn back the other way.
im thinking that if i get it to turn so many degrees right and then back the other way twice as much it should find the line. i am having trouble setting the degrees and turning it the right amount
at the moment im using the example in the nxc tutorial pdf by Daniele benedettelli
#define THRESHOLD 40
SetSensorLight(IN_3);
OnFwd(OUT_AC, 50);
while(true)
if (Sensor(IN_3) > THRESHOLD)
OnFwd(OUT_A, 50);
Wait(100);
until(Sensor(IN_3) <= THRESHOLD);
OnFwd(OUT_AC, 50);
this is what i have been playing with. im thinking about trying to get the robot to turn using something other than the OnFwd command as i feel this doesn't really give you the turning control required. i will look further into the rotate motor commands. if anyone has any suggestions on this i would really appreciate the help!
thanks
simon
OnFwd(OUT_AC, 50);
while(true)
OnFwd(OUT_A, 50);
Wait(100);
OnFwd(OUT_AC, 50);
thanks
simon
Users browsing this forum: Semrush [Bot] and 7 guests
