Self balancing motor bike
				nxtstep1950
Hello everybody,
Short presentation : Since 4 years, I am an enthusiast builder of Lego Technic bricks for the frame and MindStorms components for the artificial intelligence. Amongst various relevant réalisations, I have Rex, a GPS/compas driven off-road car and a "SegWay" design from HiTechnic.
For now, I would like to experiment a self balancing bike based on the design of JTM Mutsaerts (University of Delft - NL).
Project name is NXTBike-GS. Video : http://www.youtube.com/watch?v=o7nSQ2ycGX4
The hardware is ready, but I lack a lot on the adequate mathematical rules for finding the balancing équations and sensor filters to apply to get my bike standing up (drive and steer). A few programs I saw were far too complex to understand for me and to implement correctly (MatLab, LabView,SimuLink,NXTosek, Robot_C, ...)
My questions are :
As far as you know, are there any ressources written in NXT-G V2.0 available (open source) for realizing my self balancing motor bike ?
Are there any good technical references that could help me writing the application ?
Are there any distinguished Member that has build such a self balancing motor bike and would accept to share some knowledge ?
I thank you in advance for any advises.
Thank you & best regards
My questions are :
Re: Self balancing motor bike
I would try using a PID controller.
p, i, d surely must be found empirically, a complete mathematical model for this self-balancing bike is beyond everything I can imagine for the moment.
But I actually don't know if there is a PID controller already written in NXT-G.
And if you'd try to build something by your own: consider that this is a University project as it appears to be.
				mcsummation
HiTechnic has a PID block for NXT-G.  Look at http://www.hitechnic.com/downloadnew.php?category=13, most of the way down the page.  Look for "HiTechnic Motor PID Block".
							McSummation aka James
The only PID block I can find at Hitechnic's  website is a motor PID block. This is  probably a motor-speed controller related to motor encoder targets.
But in the case of the TOP question a PID controller for motor speed related to gyro or accelerometer data would be needed - that is supposed to be something quite different (CMIIW).
In fact, the mathematical approach would be more like in the HT balancing segway robot based on gyro data.
If I read this correctly, you would like someone to share the knowledge about self-balancing, and all the stuff you've see so far has been too complex to understand.nxtstep1950 wrote: The hardware is ready, but I lack a lot on the adequate mathematical rules for finding the balancing équations and sensor filters to apply to get my bike standing up (drive and steer). A few programs I saw were far too complex to understand for me and to implement correctly (MatLab, LabView,SimuLink,NXTosek, Robot_C, ...)
My questions are :
Given that, I would suggest you attempt something simpler to start with. Given that you have a "SegWay", you should be able to use the same concepts for a bike. If you don't understand the math rules, you should try to understand that better, before moving on.
If you have any questions, I'm sure there are several people who could help.
--->   Link to lots of MINDSTORMS stuff under my picture   --->
				mcsummation
I just got my NXT brick freed up from a previous project. I do not have all the parts to build the bike (the tires, maybe some other parts) so I will need to order them. When I get it built, I will work with you to get it programmed in NXT-G v2. We can then share the code with other people. (It will be several days before I can get the parts.)nxtstep1950 wrote:Are there any distinguished Member that has build such a self balancing motor bike and would accept to share some knowledge ?
Is this OK?
				nxtstep1950
First, let me say "Thank you" for the inputs provided up to now. I'll take them in account.
@ mcsummation :
This is OK, and I 'll be happy to share discussions and NXT-G codes about this very challenging but exciting project at the happyness of all MindStorms project builders.
As suggested by the site "http://bicycle.tudelft.nl/schwab/Bicycle/" itself, here you can download the design (NXTbike-GS Design.pdf) and the building instructions (NXTbike_GS_Building_Instructions.pdf).
Credits to : TU Delft (NL) - Mr Schwab & Mr. JTM Mutsaerts.
http://www.mathworks.com/matlabcentral/ ... ange/27694
http://bicycle.tudelft.nl/schwab/Bicycl ... Design.pdf
http://en.wikipedia.org/wiki/Bicycle_an ... e_dynamics
As suggested, one may examine as well the NXT-G codes provided by HiTechnic for the HTWay (SegWay alike)
URL : http://www.hitechnic.com/blog/gyro-sensor/htway/
SegWay is a TradeMark
Best regards
						@ mcsummation :
Best regards
				mcsummation
I was looking at the wheels/tires that are used in the bike.  What size does it say on the tire?  Is it 81.6 x 15?  The BrickLink reference is http://www.bricklink.com/catalogItemInv.asp?P=2903c01.
				nxtstep1950
The Lego inventory list shows N° 290301 for the wheels and n°4563182 for the tires.
So, I think, It looks good.
   Rgds
				nxtstep1950
For our coordination, my model shows the following data :
Gravity of acceleration : g = 9,81 m/sec2
Mass of Wheel : 0,03 kg
Radius of Wheel : 0,040 m
Total weight : 0,710 kg
Weight on front Wheel : 0,230 kg
Weight on rear Wheel : 0,480 kg
L-base : 0,240 m
L-trail : 0,01 m
Head_angle = 70 deg
V= 0,6 m/sec (I suppose)
Changes from model :
I have put a LiPo battery on the NXT brick
I have put the gyro sensor in the middle of the body instead of on the side
    Rgds
L-base : 0,240 m
L-trail : 0,01 m
Head_angle = 70 deg
