Why not use a string for binary data? I need to merge pieces together, and being able to do things like string x = y + z is so much easier than resizing an array, and copying in the data. I haven't ever tried returning an array from a function, but I know I can return a string. Also, I didn't realize that there was the possibility of writing anything
but a string to a file.
Sorry, I didn't mean to be keeping the code a secret. It's just that normally when someone posts a large program with #include s, you ask for an example program that demonstrates the problem.
Here is the main program:
#include "File BMP Mono lib.nxc"
#include "File.nxc"
#define Width 128
#define Hight 128
#define Size  2048
#define uint32_t unsigned long
#define AdvSize 1.40625           // convert 0-255 to 0-359
uint32_t gray_encode(uint32_t b)
    return b ^ (b >> 1);
uint32_t gray_decode(uint32_t g)
    for (uint32_t bit = 1 << 31; bit > 1; bit >>= 1)
        if (g & bit) g ^= bit >> 1;
    return g;
void PointOutBMP(unsigned int x, unsigned int y, unsigned int width, unsigned int hight, byte & data[], unsigned int options = DRAW_OPT_NORMAL){
  byte Bytes_Per_Line = (width + 7) / 8;     // Get the minimum number of bytes used.
  while(Bytes_Per_Line%4){                   // While it isn't a multiple of 4 ...
    Bytes_Per_Line ++;                       // ... keep adding to it
  unsigned int Y_Offset = y * Bytes_Per_Line;
  unsigned int X_Offset = x / 8;
  unsigned int data_pointer = Y_Offset + X_Offset;
  byte mask = 0x80 >> (x % 8);
  switch (options){
    case DRAW_OPT_NORMAL:
      data[data_pointer] &= (~mask);
    break;
    case DRAW_OPT_CLEAR:
      data[data_pointer] |= (0xFF&mask);
    break;
void ClearScreenBMP(unsigned int size, byte & data[]){
  ArrayInit(data, 0xFF, size);
task main(){
  byte BMP[];
  ClearScreenBMP(Size, BMP);
  for(float i=0; i<10; i+=0.5){
    byte gray = gray_encode(i);
    for(int ii=0; ii<8; ii++){
      if((gray >> ii) & 1){
        PointOutBMP((ii*3+43)*sind(i*AdvSize) + 64, (ii*3+43)*cosd(i*AdvSize) + 64, Width, Hight, BMP);
  string BMP_String = CreateMonochromeBMP(BMP, Width, Hight);
  ArrayInit(BMP, 0, 1);
  NumOut(0, LCD_LINE1, strlen(BMP_String));
  PlayTone(3500,100);
  Wait(100);
  until(ButtonPressed(BTNCENTER, false));
  until(!ButtonPressed(BTNCENTER, false));
  WriteFileSingle("test image.bmp", BMP_String);
  PlayTone(5000,100);
  Wait(100);
and "File BMP Mono lib.nxc":
string CreateBMP_Header(unsigned long TotalSize, unsigned long OffsetToBitmap){
  byte data[14] = {
    0x42, 0x4D,
    0x00, 0x00, 0x00, 0x00,  // will get replaced
    0x00, 0x00,
    0x00, 0x00,
    0x00, 0x00, 0x00, 0x00   // will get replaced
  data[2] = TotalSize;
  data[3] = TotalSize >> 8;
  data[4] = TotalSize >> 16;
  data[5] = TotalSize >> 24;
  data[10] = OffsetToBitmap;
  data[11] = OffsetToBitmap >> 8;
  data[12] = OffsetToBitmap >> 16;
  data[13] = OffsetToBitmap >> 24;
  return FlattenVar(data);
string CreateDIB_Header(
  unsigned long DIB_Len,
  unsigned long Width,
  unsigned long Hight,
  unsigned int Color_Planes,
  unsigned int Bits_Per_Pixel,
  unsigned long Compression,
  unsigned long PixelArrSize,
  unsigned long HorzRes,
  unsigned long VertRes
  unsigned long Colors_In_Palette,
  unsigned long Important_colors){
  byte data[40];
  data[0]  = DIB_Len;
  data[1]  = DIB_Len >> 8;
  data[2]  = DIB_Len >> 16;
  data[3]  = DIB_Len >> 24;
  data[4]  = Width;
  data[5]  = Width >> 8;
  data[6]  = Width >> 16;
  data[7]  = Width >> 24;
  data[8]  = Hight;
  data[9]  = Hight >> 8;
  data[10] = Hight >> 16;
  data[11] = Hight >> 24;
  data[12] = Color_Planes;
  data[13] = Color_Planes >> 8;
  data[14] = Bits_Per_Pixel;
  data[15] = Bits_Per_Pixel >> 8;
  data[16] = Compression;
  data[17] = Compression >> 8;
  data[18] = Compression >> 16;
  data[19] = Compression >> 24;
  data[20] = PixelArrSize;
  data[21] = PixelArrSize >> 8;
  data[22] = PixelArrSize >> 16;
  data[23] = PixelArrSize >> 24;
  data[24] = HorzRes;
  data[25] = HorzRes >> 8;
  data[26] = HorzRes >> 16;
  data[27] = HorzRes >> 24;
  data[28] = VertRes;
  data[29] = VertRes >> 8;
  data[30] = VertRes >> 16;
  data[31] = VertRes >> 24;
  data[32] = Colors_In_Palette;
  data[33] = Colors_In_Palette >> 8;
  data[34] = Colors_In_Palette >> 16;
  data[35] = Colors_In_Palette >> 24;
  data[36] = Important_colors;
  data[37] = Important_colors >> 8;
  data[38] = Important_colors >> 16;
  data[39] = Important_colors >> 24;
  string Sdata = FlattenVar(data);
  return Sdata;
string CreateMonochromeColorTable(){
  byte data[8] = {
    0xFF, 0xFF, 0xFF, 0x00
string CreateMonochromeBMP(byte bitmap_data[], unsigned long width, unsigned long hight){
  unsigned long length = ArrayLen(bitmap_data) + 62;
  string BuildingResult = "";
  BuildingResult += CreateBMP_Header(length, 62);
  BuildingResult += CreateDIB_Header(40, width, hight, 1, 1, 0, 0, 2835, 2835, 0, 0);
  BuildingResult += CreateMonochromeColorTable();
  BuildingResult += FlattenVar(bitmap_data);
  Wait(10);
  string Result = BuildingResult;
  Wait(10);
  return Result;
and "File.nxc":
void WriteFileSingle(string file_name, string message)
  DeleteFile(file_name);
  byte file_handle;
  unsigned long file_size = strlen(message);
  CreateFile(file_name, file_size, file_handle);
  unsigned long amount_written;
  WriteString(file_handle, message, amount_written);
  CloseFile(file_handle);
void ReadFileSingle(string file_name, string & message)
  byte File_Handle;
  int File_Size;
  bool Success = false;
  if(OpenFileRead(file_name, File_Size, File_Handle) == NO_ERR)
    Success = ReadLnString(File_Handle, message);
  CloseFile(File_Handle);
task main(){
  string Message;
  for(int i = 0; i<500; i++){
    Message = Message + NumToStr(i) + " ";
  string name = "Test file.txt";
  WriteFileSingle(name, Message);
It's supposed to create a BMP image file on the NXT file system. If it creates it successfully, you can see what it's supposed to look like (or look on FaceBook for a similar image I posted earlier).
