Large numbers on the NXT screen
sqiddster
Post by sqiddster »
For a current project, I would like to be able to display fairly large numbers on the NXT screen, about 3 times as large as the current ones would be good.
I am using NXT-G. I heard of an advanced text display block, but with the death of NXTasy
*moment of silence*
it is nowhere to be found!
Some help would be appreciated.
Many thanks, sqiddster.
Keep on brickin'
ronmcrae
Re: Large numbers on the NXT screen
Post by ronmcrae »
Here's a RIC based font file that works with the NXT-G Advanced Text Display Block. You just need to get the file into the same directory as the fonts supplied with the block and it'll show up in the drop down window.
The characters are 8*12 pixels with a 1 pixel border. That makes the text about 1.5 times the standard font; smaller than you want but definitely a lot more readable. I also have a font with characters 31 pixels tall but that's probably bigger than you want.
Ron.
9x13font.zip
(1.15 KiB) Downloaded 727 times
hi
here is a collection of fonts (up to 12pt), a test program (printfgr3.nxc), and a tool (RicFont.exe) by which you can quickly construct your own custom fonts of any size out of Windows fonts
HTH!
RicFontsNXC.zip
RIC fonts and font tools
(405.9 KiB) Downloaded 824 times
sqiddster
Post by sqiddster »
Thanks everyone, but what I'm really looking for is a way to get the advanced text display block.
Keep on brickin'
xrsfisher
Post by xrsfisher »
You can find it on Team Hassenplug.
ronmcrae
Post by ronmcrae »
xrsfisher wrote:You can find it on Team Hassenplug.
That link is for advanced image display, slightly different than advanced text display.
I've attached my archived version of advanced text display from nxtasy. Hopefully a repository can get added somewhere here to contain this type of recovered stuff.
Ron.
Advanced Display Text.zip
(227.34 KiB) Downloaded 790 times
Anything that seems appropriate for the new MindBOARDS repository can be added to the repository folder here:
http://sourceforge.net/projects/mindboards/files/
You can send archives or source code files that you can recover from the old forums or that you think would be beneficial to the MINDSTORMS community to my afanofosc or bricxcc email address at comcast dot net and I will upload them to the repository folder.
sqiddster
Post by sqiddster »
Many thanks. This is too bad that NXTasy block repository is gone, there were so many useful blocks!
Keep on brickin'
sqiddster
Post by sqiddster »
Ronmcrae, that 31 pixel font would actually be perfect.
Could you attatch that?
P.S. how do you install the fonts? I tried to just unzip the file to the 'fonts' directory, but that doesn't seem to be working.
Keep on brickin'
sqiddster
Post by sqiddster »
Hmm. Ronmcrae seems to have disappeared...
Does anyone have a good font? It needs to be as big as possible, as long as 4 number digits can fit across the screen.
Keep on brickin'
Users browsing this forum: Semrush [Bot] and 8 guests
