plz Help; How to make a robot follow Distance? (NXC)
onewinged
Post by onewinged »
Dear memebers,
I'm a college student who's new in programming with NXC
but I came across a problem which is ,I don't know how to make an NXT robot walk for a specific distance ?
for instance: I want to make the robot move forward 7 meters ??
what's the code?
Re: plz Help; How to make a robot follow Distance? (NXC)
if you mean "go ahead" by wheels :
you may calculate how many rotations you need for each wheel to go 7 meters.
for instance, if the wheel circumference is 20 cm, you need 35 rotations with 360° each = 35*360 = 12600 encoder counts
so start your engines
monitor the rotation counts
and if rotation counts >= 12600 then stop your engines.
If you mean "walk" for a humanoid robot, you will have to count the step size analogously instead of wheel rotations.
Of course more advanced navigation algorithms are possible, based on odometry, compass, and gyro sensor - such a project is already discribed in the projects subforum.
HTH!
onewinged
Post by onewinged »
doc-helmut wrote:if you mean "go ahead" by wheels :
it's exactly as you said
but I'm using NXC and the code for moving forward is like this one >>
OnFwd(OUT_C, 75);
Wait(4000);
as I studied, I conclude that it means move forward with a speed of 75 for 4 seconds :)
but I need is to make it move by distance not speed ?
I thought maybe to use the equation (D=S x T T=D/S S= D/T /=divide x=multiply. D=distance. S=speed. T=time) by calculating the amount of time the robot takes to do 1 meter with a speed of 75 ...
but I need a better solution coz Im not sure if that will work
thank you so much ,,,and sorry for my poor english ^_^"
From the NXC Programmer's Guide byJohn Hansen
RotateMotor(outputs, pwr, angle) Function
Run the specified outputs forward for the specified number of degrees.
Outputs can be a constant or a variable containing the desired output ports.
Predefined output port constants are defined in Table 20.
RotateMotor(OUT_A, 75, 45); // forward 45 degrees
RotateMotor(OUT_A, -75, 45); // reverse 45 degrees
RotateMotorEx(outputs, pwr, angle, turnpct, sync, stop) Function
If a non-zero turn percent is specified then sync must be set to true or no turning will occur.
Specify whether the motor(s) should brake at the end of the rotation using the stop parameter.
RotateMotorEx(OUT_AB, 75, 360, 50, true, true);
You can find all commands in the documentation, the most up-to-date version is found here: http://bricxcc.sourceforge.net/nbc/nxcdoc/nxcapi/. The motor commands are found in "Modules->NXT Firmware Modules->Output module". Be aware that some commands require the latest test version of BCC and the enhanced firmware in order to work. You can get the test releases here: http://bricxcc.sourceforge.net/test_releases/
you also may use OnFwd, but as I mentioned, you also have to monitor the encoder:
OnFwd(OUT_C, 75); // start motor C by power 75%
while (MotorRotationCount(OUT_C)<12600); // wait until target count reached
Off(OUT_C); // then switch off motor
Maybe you wish to have a look at the NXC tutorial by Daniele Benedettelli? http://bricxcc.sourceforge.net/nbc/nxcd ... torial.pdf
onewinged
Post by onewinged »
THANKS A LOT GUYS FOR THE HELP
doc-helmut wrote:you also may use OnFwd, but as I mentioned, you also have to monitor the encoder:
I guess I'll be following the counting method
but..
I just have one more questions if you may! :)
I don't get how you interpreted the 35 rotations? can you explain it plz ?
If one full rotation (360°) moves the robot 20 cm forward, the amount of rotations to go the full distance would be 700 cm / 20 cm = 35. So in degrees it would be 35 * 360° = 12600°.
onewinged
Post by onewinged »
spillerrec wrote:If one full rotation (360°) moves the robot 20 cm forward, the amount of rotations to go the full distance would be 700 cm / 20 cm = 35. So in degrees it would be 35 * 360° = 12600°.
aha! now I get it !
thanks a million ;D
Users browsing this forum: Semrush [Bot] and 30 guests
