NXC: Type conversion problems
I have had a report of issues with the latest test release of NXC that involve converting between floats and ints. Matthew if you could respond here with the problems you have encountered I'd be grateful. If anyone else could run some tests with the latest test release and let me know here or via email what problems you run into that would be awesome.
Re: NXC: Type conversion problems
Run this program:I am fairly sure the results used to be the same, but now they are different.
However, if I use global variables like this:I get results as expected (they are both floating point numbers).
I haven't tried isolating the exact place that makes the difference, and I haven't tried static "local" variables. NXC doesn't support type casting, so I obviously can't test it with that either.
BTW, the reason for the Wait(0);s is so that it is easier to identify the operations in NBC.
I also just noticed that I had my compiler optimization set to 1, instead of 2 (no idea why I would have changed it...). That makes a difference (2 works as expected for local variables).
I guess the issue I found is when the optimization is 1, and I use local variables.
task main(){
int int_22 = 22;
int int_7 = 7;
Wait(0);
float result1 = int_22 / int_7; //This used to work
Wait(0);
float result2 = int_22; //Now I have to use this...
result2 /= int_7; //... and this to get the floating point result
Wait(0);
NumOut(0, LCD_LINE1, result1);
NumOut(0, LCD_LINE2, result2);
while(true);
int int_22 = 22;
int int_7 = 7;
float result1;
float result2;
task main(){
Wait(0);
result1 = int_22 / int_7; //This works
Wait(0);
result2 = int_22; // and this works
result2 /= int_7; // ''
Wait(0);
while(true);
The expected output is:mattallen37 wrote:Code: Select all
task main(){ int int_22 = 22; int int_7 = 7; Wait(0); float result1 = int_22 / int_7; //This used to work Wait(0); float result2 = int_22; //Now I have to use this... result2 /= int_7; //... and this to get the floating point result Wait(0); NumOut(0, LCD_LINE1, result1); NumOut(0, LCD_LINE2, result2); while(true); }
3.142857
This is how it should work:
f = 22/7;
f = float(22/7); // 'coercion' or implicit type conversion
f = float(3);
f = 3.0;
Muntoo, I don't agree with you, and neither does the compiler on optimization level 2. Also, neither does another compiler I use. If I use a type cast float(), even if I enter constants, it should output the value in float... or else the type cast is mostly pointless...
I don't understand yet where the problem is.
I agree with muntoo that for integer division integer/integer this would be expected as far as I observed NXC hitherto:
If one of the deviding numbers was float, then I would expect a type coast to float:
Of course both should happen no matter which O.L. or if they were global or local variables.
What exactly happens at what time to your observations, Matt?
f = 22/7;
f = float(22/7); //no type conversion
f = float(3);
f = 3.0;
f = 22.0/7;
f = float(22.0/7); //implicit type conversion
f = float(3.142857);
f = 3.142857;
In C, types are usually converted at the last possible moment. For example,
Will evaluate the expression on the rhs (right-hand side). Since none of the values are of type
After that, we go into the brackets, and do the multiplication, then addition, followed by division, and lastly, multiplication again.
See? Types are only converted at the last possible moment; this is partly due to performance reasons, but it's also more logical that way, IMHO.
See also: 4.4 — Type conversion and casting.
f = (10*14 + 4) / 10 * 1.0f;
f = float(EVALUATE_THIS_FIRST);
float
, no type conversions take place there. (Type conversions are expensive.)After that, we go into the brackets, and do the multiplication, then addition, followed by division, and lastly, multiplication again.
f = (140 + 4) / 10 * 1.0f;
f = (144 ) / 10 * 1.0f;
f = 14 * 1.0f;
f = float(14) * 1.0f;
f = 14.0 ;
f = 14.0; // Implicit conversion to float is unnecessary.
muntoo,
that's more or less the same as I said (with Matt's example).
But what's Matt's problem which he observed (concerning O.L. and local or global declarations)?
ps
If I really NEED to avoid unexpected a/o unwanted results I meanwhile use this:
ps
inline float FLOAT(long x){return(x);}
