NXC string manipulation
Posted: 23 Jun 2011, 02:29
First, I want to say that I don't know the exact term I should use. I think it is "struct", but please correct me if I'm wrong.
I want to have a file with an undetermined number of lines. I want to read it into a struct.
What I have been doing is this:I specify the max number of lines, and it creates the string to that size. However, I don't want to use more memory than I need to.
After I create that string, I read the individual lines into it using this lib function I coded:At the end, I have it fill the remaining strings of the struct with "" (nothing).
How can I size it to the exact number of lines, efficiently? For arrays, I use "ArrayInit", and that's supposed to be good, but how do I do it for structs?
How do you recommend I read a file into a struct of strings? I want to address the lines (individual strings) with a variable like this "Original_Message[LineToRead];".
#define Max_number_of_lines 25
string Original_Message[Max_number_of_lines];After I create that string, I read the individual lines into it using this lib function I coded:
void ReadFile(string file_name, int & Read_Line_i, string & message_struct[])
byte File_Handle;
int File_Size;
string File_Line_Message;
bool Rdone = false;
if(OpenFileRead(file_name, File_Size, File_Handle) == NO_ERR)
until (Rdone == true) // read the text file till the end
if(ReadLnString(File_Handle, File_Line_Message) != NO_ERR) Rdone = true;
message_struct[Read_Line_i] = File_Line_Message;
Read_Line_i++;
CloseFile(File_Handle);
for (int i=Read_Line_i; i < Max_number_of_lines; i++){ //Fill the rest with nothing
message_struct[i]="";
}How can I size it to the exact number of lines, efficiently? For arrays, I use "ArrayInit", and that's supposed to be good, but how do I do it for structs?
