FW: bad rand generator: distribution/prevalences/periodicity
hello,
I now have tested the random number generator of the Lego FW statistically by 1 million randomizations of numbers between 0-15 (inclusive)
The result is shocking:
Some numbers are generated almost twice as often as others, and, worse, they are always even the same at different test runs :
Lego fw rand function, run number 1
Lego fw rand function, run number 2
this is the test code:
// Test on statistical equal distribution of Lego and customized randomization
  TextOut(_x, _y, sval1); \
char LCDline[]={56,48,40,32,24,16,8,0};
task main(){
  long i, j;
  long H[16];            // prevalence counter array
                         // print output matrix
  for (j=0; j<16; ++j) {
    printf1(0+(j%2)*50, LCDline[j/2], "%2d:", j);
  //srand(1);       // standard seed (only for customized randomization function)
  for (i=0; i<1000000; ++i) {
    // 1 Million randomizations of numbers between 0...15
    j=rand()%16;        // std Lego FW randomization function
    // alternatively:
    //j=rand_()%16;       // customized randomization function
    H[j]+=1;            // add +1 to the prevalence to the related counter
                        // print prevalence test distribution
    printf1(16+(j%2)*50,LCDline[j/2], "%5d", H[j]);
  PlaySound(SOUND_FAST_UP);
  while(1) {}
Now I tested the code I got from a guy from a German Informatik-Forum https://bildungs-foren.de/foren/viewforum.php?f=3 which I already published here in a different thread :
//of Lego and customized randomization functions
// randomize functions
// global variables and functions to plant a random seed and to randomize
// how to use:
// srand(x)                         // x = val. for repet. sequences
// myVar = rand_() % 100;           // assignes a random number
unsigned long _RAND_SEED_ = 1;      // 1= default value (program start)
unsigned long _OLD_SEED_  = 1;
unsigned long rand_()               // random function
  _RAND_SEED_ = _RAND_SEED_ * 1103515245 + 12345;
  return (_RAND_SEED_ % (RAND_MAX + 1));
void srand(unsigned long seed)      // seeds for a new random series
  if (seed==0)                      // 0: a "real" randomized random seed
    {seed = abs(CurrentTick()*BatteryLevel());}  // substitute to time(0)
  if (seed==-1) {                   // -1: restore last random series
    seed = _OLD_SEED_;
  _OLD_SEED_  = seed;
  _RAND_SEED_ = seed;               // patch for rand_ function
task main(){
  long i, j;
                         //  (only for customized randomization function)
  srand(1);              //  reproducible standard seeds 1 (2, 3, 4, ...)
                         //  alternatively:
  //srand(0);            //  randomized random seed (time(0)*Voltage)
    //j=rand()%16;        // std Lego FW randomization function
    // alternatively:
  while(1) {}
Result: absolutely equally distributed prevalence!
custom rand_ function, initialized by standard seed = 1
Re: Lego FW: extreme poor equal distribution of random series
ps:
this is the 2nd run of the custom random function rand_(), seed(0)= (systemTime*BatterLevel) - also perfectly equally distributed:
custom random function, 2nd run, seed(0)= (systemTime*BatterLevel)
Re: Lego FW:extrem poor equal distribution of random prevalences
I know. My "randomly generated" mazes were so un-random, and followed a very obvious pattern that I'd almost given up trying to generate random mazes. Even the Mersenne Twister didn't work, for some reason. Or maybe it was my code
(I might have done something dumb like:
int rand4()
    return(Random() >= 4 ? 3 : Random());
if you wish try my code! :)
I don't know much about the subject, however I know it is normally recommended not to use modulus when using small ranges.
Try the standard NXC random function instead:
j=Random(16);
It is only about 26000 right now, but they are perfectly equally distributed.
I remember looking into the NBC code for rand() and Random() and they are quite different and I think there was something weird with one of them. I don't quite remember what (as it was half a year ago) and I don't have time today since I need to attend my final exam in Computer Science tomorrow...
ARGH, the NXT automatically turned off at about 36000... -__-
modulo is the regular way to get a range of random numbers by using rand() in ANSI C code.
http://www.c-plusplus.de/forum/39344
http://www.daniweb.com/software-develop ... reads/1769
if modulo gives faulty prevalences then (edit: above all!) also the underlying NXC rand() function is faulty (independend of the size of the range, whether small or big).
But maybe the not-C-function Random() might indeed work better...
Yes, modulus is the regular way, but that doesn't mean it is the best way.
As far as I have heard the issue is that many number generators isn't random enough at the lower significant bits, so you need to use bits at a higher range of bit to ensure that it is completely random. This is where modulus with lower values fail.
If you do a bit of searching you can find some of the other methods to limit rand() which does not use modulus.
Both rand() and Random( x ) use the same random number generator however Random( x ) limits the range with some arithmetics I didn't quite understood, but as you can see it clearly makes a difference. I will look into how the NBC code is generated tomorrow.
spiller wrote:As far as I have heard the issue is that many number generators isn't random enough at the lower significant bits
Helmut wrote:if modulo gives faulty prevalences then (above all!) also the underlying NXC rand() function is faulty (independend of the size of the range, whether small or big).
MY random generator IS good enough even at low bits :)
I'm on a "long weekend vacation" from Friday enening, but some other tests will have to be done, e.g. the examiniation of the statistical equal deviation of the difference of all sequential numbers to prove if there are obscured serial dependencies of generated numbers...
... the equal distribution of 2 consecutive numbers...
...the examiniation of the statistical Normal (Gaussian) deviation of the differences of the differences of the the statistical equal deviation of all sequential numbers...
...and then other tests if there are illegal clusters of sequential sub-series ("real random numbers series" in fact always have some "legal clusters" but the difference of both is not easily to distinguish (or: differ?) from each other )...
...and...
...and...
I've set up a Mercurial repository for NXC-based RNG libraries here. If you want to become a contributor (and are comfortable with version control systems), PM me your email or "fork and pull request".
Here's how Java implements their rejection sampling for Random.nextInt(). You don't want to be out done by those losers, do you? :)
