Page 1 of 2
Display Time Block Bug
Posted: 29 Apr 2011, 06:15
by bungeshea
I have noticed a bug with the Display Number/Display Time blocks from
Team Hassenplug. If you wire a timer into these blocks and place it in a loop, when the timer reaches 33 seconds, instead of displaying 0:33:00 it displays 0:-31:00 and continues counting down in minus until it reaches 0:00:00 and then it starts happening all over again. I have attached a video made with NeXT Screen and Hyper Cam 2, and the test program. Does anyone else experience this bug?
Display Time Bug.zip
(Because the attachment file will not upload, follow the above link to download it from the Mindboards Repository)
Re: Display Time/Number blocks bug
Posted: 29 Apr 2011, 07:07
studbrickmaster wrote:...I have attached a video ... and the test program...
Where is it?
Posted: 29 Apr 2011, 07:49
by bungeshea
mattallen37 wrote:studbrickmaster wrote:...I have attached a video ... and the test program...
Where is it?
It was not uploading with the message. I do not know if it is an issue of size (2.1MB) or just phpBB. I have uploaded the file to
here.
Re: Display Time Block Bug
Posted: 29 Apr 2011, 08:09
by timpattinson
studbrickmaster wrote:I have attached a video made with NeXT Screen and Hyper Cam 2, and the test program.
Can't you just use the Capture AVI feature in NXTScreen
Posted: 29 Apr 2011, 08:37
by bungeshea
timpattinson wrote:studbrickmaster wrote:I have attached a video made with NeXT Screen and Hyper Cam 2, and the test program.
What capture AVI feature?
Posted: 29 Apr 2011, 08:52
by timpattinson
studbrickmaster wrote:timpattinson wrote:studbrickmaster wrote:I have attached a video made with NeXT Screen and Hyper Cam 2, and the test program.
Posted: 29 Apr 2011, 09:31
by bungeshea
Posted: 29 Apr 2011, 11:12
by timpattinson
Try upgrading nxtscreen/bricxcc
Which one are you using.
Posted: 29 Apr 2011, 12:18
by h-g-t
There are 2 links to the file - who cares what he used to create it?
Posted: 29 Apr 2011, 16:04
It does that because the value is a 16-bit signed value. Because time can't be negative, the block should use either an unsigned 16-bit variable (up to ~65,000), or an unsigned 32-bit variable (up to >4,000,000,000).
