Maps for The Knight
nxtboyiii
Maps for The Knight
Post by nxtboyiii »
post your maps you made for The Knight nxt game here!! just post the text file
Re: Maps for The Knight
I made one
timpattinsons_map.zip
a map. You need extract it and rename the file inside to map.txt for it to work
(271 Bytes) Downloaded 1060 times
Maybe it would help if you posted a tutorial on how to make a map.
Also. if you changed you program to make it read a .map file and changed the map to map.map then you could use the functions of the enhanced firmware to list all the map files and give the user a choice about which map to play so you could play more than one map without re-downloading the program.
