Trouble understanding the use of OpenFileAppend in NXC
Posted: 03 Apr 2011, 15:57
I do not understand how OpenFileAppend() in NXC should work.
My goal is to open file and write data to it. If a file with the specified name allready exist, I want to append to that file. Otherwise I want to create a new file.
Here is how I think to accomplish that:
Unfortunate I get a wrong response from the OpenFileAppend(FILE_NAME,file_size,file_handle) back (I think): 8E00, FILEISFULL
What am I doing wrong?
I use Bricxcc 3.3.8.9 and NXT enhanced firmware 1.31 (2011-03-15)
I have created an other piece of code (down here) that illustrates the operation:
After the first run a new file called test.csv is created. This is the output on the NXT screen:
When I look with the Bricxcc File Explore I can see that after the first run that the file was create succesfully and that the string "succesfull" was written to the file.
The loader module error that were returned when the file was created (0000, LDR_SUCCESS) and when OpenFileAppend() was executed (8b00, LDR_FILEISBUSY) are as expected.
The next time I run the code this is the output on the NXT screen:
After the second run there isn't any data added to the file.
Attempting to create the file will of course returns error 8f00, LDR_FILEEXISTS. When attempting to execute OpenFileAppend() the loader module returns error 8e00, LDR_FILEISFULL. That is not what I would expected. I would expected that it returns 0000, LDR_SUCCESS.
The link http://bricxcc.sourceforge.net/nbc/nxcd ... rrors.html gives an explanation of the loader module error codes, but they are not always clear to me.
I hope someone can help me out.
Best regards,
Ted Sluis
string FILE_NAME="test.csv";
byte file_handle;
unsigned int loader_result_code;
const int file_size=1024;
loader_result_code=CreateFile(FILE_NAME,file_size,file_handle);
if (loader_result_code == LDR_FILEEXISTS)
loader_result_code=OpenFileAppend(FILE_NAME,file_size,file_handle);
if (loader_result_code == LDR_SUCCESS)
loader_result_code=Write(file_handle,"succesfull");
byte file_handle;
switch (loader_result_code)
case LDR_SUCCESS:
TextOut(0,LCD_LINE1,"created succesfull!");
break;
case LDR_FILEISFULL:
TextOut(0,LCD_LINE1,"file is full!");
break;
case LDR_FILEEXISTS:
TextOut(0,LCD_LINE1,"file exist.");
break;
case LDR_INPROGRESS:
TextOut(0,LCD_LINE1,"not yet completed.");
break;
case LDR_FILEISBUSY:
TextOut(0,LCD_LINE1,"file already used.");
break;
default:
TextOut(0,LCD_LINE1,"create failed!");
break;
TextOut(0,LCD_LINE2,"filesize="+NumToStr(file_size));
TextOut(0,LCD_LINE3,"result code="+FormatNum("%04x", loader_result_code));
TextOut(0,LCD_LINE4,"file_handle="+NumToStr(file_handle));
case LDR_SUCCESS:
TextOut(0,LCD_LINE5,"append succesfull!");
break;
TextOut(0,LCD_LINE5,"file is full!");
break;
TextOut(0,LCD_LINE5,"not yet completed.");
break;
TextOut(0,LCD_LINE5,"file already used.");
break;
default:
TextOut(0,LCD_LINE5,"append failed!");
break;
TextOut(0,LCD_LINE6,"filesize="+NumToStr(file_size));
TextOut(0,LCD_LINE7,"result code="+FormatNum("%04x", loader_result_code));
TextOut(0,LCD_LINE8,"file_handle="+NumToStr(file_handle));
Wait(80000);
CloseFile(FILE_NAME);
created succesfu
filesize=1024
result code=0000
filehandle=1
file allready use
filesize=1024
result code=8b00
filehandle=2
file exist.
filesize=1024
result code=8f00
filehandle=1
file=full!
filesize=1024
result code=8e00
filehandle=1
Best regards,
Ted Sluis
