Declaring the length of an array with a variable
Posted: 25 Feb 2011, 02:50
This works:
byte ArrayOne[];
byte ArrayTwoLength;
ArrayTwoLength=ArrayLen(ArrayOne)-3;
byte ArrayTwo[ArrayTwoLength];
But not this:
byte ArrayOne[];
Why does the variable that defines the length of an array need to be global? Is there any special reason, or is it just a bug?
I want to be able to do something like the following:
byte ArrayOne[];
byte ArrayTwoLength=ArrayLen(ArrayOne)-3;
where the variable is obviously local, and when it is defined, it is also assigned a value.
Of course, so far I haven't run into a situation where this is really a problem, as there is a workaround. I am just curious as to the reason it must be global.
Re: Declaring the length of an array with a variable
Posted: 25 Feb 2011, 03:24
by afanofosc
I would not try to use a variable in the way that you are trying. Instead use ArrayInit(array, value, len_variable);
Posted: 25 Feb 2011, 03:30
So, does this declare an array, or just resize it? What is the "value" parameter for?
Posted: 25 Feb 2011, 08:24
mostly zero, 42, or your lucky numbers :)
Posted: 25 Feb 2011, 08:30
doc-helmut wrote:mostly zero, 42, or your lucky numbers
Actually, that would be 0b101010 (or %101010)
Based on the help files, it looks like it is the value that it gives to all the elements of the array. Is that right?
Posted: 25 Feb 2011, 08:31
yes, IMHO :)
Posted: 26 Feb 2011, 05:09
by muntoo
mattallen37 wrote:Based on the help files, it looks like it is the value that it gives to all the elements of the array. Is that right?
It's true as much as the answer to the life the universe and everything is 42.
BTW,
just something completely unrelated I thought you guys/gals/aliens/robots/von Neumann machines/etc might find interesting:
Posted: 26 Feb 2011, 05:35
by afanofosc
Yes, the value is the thing that gets copied into all len_variable elements in the newly reallocated array. If it is an array of structures or an array of strings or an array of arrays of int or whatever then the value should be of the appropriate type. I.e., do not ArrayInit an array of LocationType structs with the constant 0 or an empty string or some other kind of struct. That would be a bad thing to do.
Posted: 27 Feb 2011, 03:53
by muntoo
Yeah, I've started using this whenever I want to initialize a LocationType (or whatever struct/etc):
LocationType ltOut[];
LocationType ltTemp;
ltTemp.X = 0;
ltTemp.Y = 0;
ArrayInit(ltOut, ltTemp, 42);
