Declaring the length of an array with a variable
This works:
byte ArrayOne[];
byte ArrayTwoLength;
  ArrayTwoLength=ArrayLen(ArrayOne)-3;
  byte ArrayTwo[ArrayTwoLength];
But not this:
byte ArrayOne[];
Why does the variable that defines the length of an array need to be global? Is there any special reason, or is it just a bug?
I want to be able to do something like the following:
byte ArrayOne[];
  byte ArrayTwoLength=ArrayLen(ArrayOne)-3;
where the variable is obviously local, and when it is defined, it is also assigned a value.
Of course, so far I haven't run into a situation where this is really a problem, as there is a workaround. I am just curious as to the reason it must be global.
Re: Declaring the length of an array with a variable
I would not try to use a variable in the way that you are trying. Instead use ArrayInit(array, value, len_variable);
So, does this declare an array, or just resize it? What is the "value" parameter for?
mostly zero, 42, or your lucky numbers :)
doc-helmut wrote:mostly zero, 42, or your lucky numbers :)
Actually, that would be 0b101010 (or %101010) :lol:
Based on the help files, it looks like it is the value that it gives to all the elements of the array. Is that right?
yes, IMHO :)
mattallen37 wrote:Based on the help files, it looks like it is the value that it gives to all the elements of the array. Is that right?
It's true as much as the answer to the life the universe and everything is 42.
BTW, just something completely unrelated I thought you guys/gals/aliens/robots/von Neumann machines/etc might find interesting:
Douglas Adams wrote: Douglas Adams was asked many times during his career why he chose the number 42. Many theories were proposed,[6] but he rejected them all. On November 3, 1993, he gave an answer[7] on alt.fan.douglas-adams:
“ The answer to this is very simple. It was a joke. It had to be a number, an ordinary, smallish number, and I chose that one. Binary representations, base thirteen, Tibetan monks are all complete nonsense. I sat at my desk, stared into the garden and thought '42 will do'. I typed it out. End of story. ”
Yes, the value is the thing that gets copied into all len_variable elements in the newly reallocated array. If it is an array of structures or an array of strings or an array of arrays of int or whatever then the value should be of the appropriate type. I.e., do not ArrayInit an array of LocationType structs with the constant 0 or an empty string or some other kind of struct. That would be a bad thing to do.
Yeah, I've started using this whenever I want to initialize a LocationType (or whatever struct/etc):
LocationType ltOut[];
LocationType ltTemp;
ltTemp.X = 0;
ltTemp.Y = 0;
ArrayInit(ltOut, ltTemp, 42);
