RS-485 power question
Posted: 23 Feb 2011, 22:13
I know that for RS-485, only two wires are required; the data wires. Although not 100% necessary, Gnd is highly recommended to be common, as a voltage stabilizer/reference for the two (or more) systems (NXT's).
What I am wondering about, is the affect of sharing the supply (4.n volts). When using just a normal NXT wire to connect the two together, all six pins are connected to each other's. In practice, both NXT's will not be powered at exactly the same times, so it is quite probable that one will be powered at times, when the other one is off (assuming only two NXT's for now). Does it matter that you would then be supplying power from the On NXT to the NXT that is off? I am not sure if it matters, and I haven't seen any warnings about it, but I always try to keep them either both on, or both off. Would it be better for me to cut a wire, and only have three or four of the pins connect through (data0, data1, Gnd, and maybe the other Gnd)?
On a slightly different note, does it matter if I have the NXT turned off, with active pullups (to a different power source) on an I2C bus?
