I've been trying to figure out exactly how to convert the TachoLimit that you give as input in the direct command part of the API. Is their a known rule for converting it to say degrees or seconds? It seems to vary so much the power set point. Also, what exactly does the Turn Ratio byte do?
Thanks,
Kami
Using the Tacholimit and Turn Ratio in the NXT API
Kami
Kami
Re: Using the Tacholimit and Turn Ratio in the NXT API
The tacho is based on degrees, thus 360 represents one complete rotation.lizard381 wrote:...Is their a known rule for converting it to say degrees or seconds?...
Users browsing this forum: No registered users and 42 guests
