NXC and nexttools debian packages
On the old nxtasy Slavko offerred repository with NXC and nexttools for debian or ubuntu.
Here it is:
http://debs.slavino.sk/
Here it is:
Re: NXC and nexttools debian packages
yes, my repo still works for all
only one thing - it is targeted to Debian testing (Ubuntu can works, but i don't know about dependencies), amd64, but some packages (no svn) are for i386 too. I still offer publishing i386 packages, if someone build them (there is one old i386 bricxcc from contrubutor)...
regards
regards
That was me
There is only a difference of 4 svn revisions according to your web page, is there a need to rebuild it?
About the -doc package, could you include the doxygen generated help?
Thanks again for your packages!
The world is smallschodet wrote:That was me
it is your choice
Yea, i can, but i don't know how – I newer use doxygen
Here are i386 packages: http://ni.fr.eu.org/~nico/nxc/
They will be removed once you have taken them.
Just go to the NXT directory and run "doxygen".slavkozn wrote:> could you include the doxygen generated help?
Actually, some options should be tuned, for example, output directory is d:\bricxcc\nxt\doxygen. You can just append options at end of Doxyfile file:
OUTPUT_DIRECTORY = doc
GENERATE_HTMLHELP = NO
GENERATE_LATEX = NO
GENERATE_RTF = NO
GENERATE_XML = NO
your packages uploaded!
thanks about doxygen, i try it in next days
I have changed the output directory in the two doxygen configuration files and checked the changes into SVN. It now uses a relative path (doxygen for NXC and nbcdoxygen for NBC).
it seems that i was successschodet wrote:Just go to the NXT directory and run "doxygen".
new bricxcc-doc includes generated html pages, can you please test it? I don't know, but IMHO some rtf files can be excluded now, can you take look on it, please?
for NXC it works fainafanofosc wrote:I have changed the output directory in the two doxygen configuration files
i got lot of missing .nxc files from NXCAPIDocs.h (by letters case), i sent patch to you by mail...
Users browsing this forum: Baidu [Spider] and 9 guests
