NXC memory game not working.
ant11
Post by ant11 »
I'm trying to create a memory game based on colours. I wrote this code and BricxCC compiles it but when i run it in my NXT ti shows a file error:
the code is this:
SetSensorColorFull(IN_1);
  int random[4];
  int color[4];
  int v = 1;
  int j = 1;
  int i =1;
  int result = 0;
    for(v = 1; v <= 4 ; v++)
      { random[v]= Random(3) + 2;
        if  (random[v] == 2)
           { TextOut (0, LCD_LINE3, "Azul");}
           else if (random[v] == 3)
           { TextOut (0, LCD_LINE3, "Verde");}
           else if (random[v] == 4)
           { TextOut (0, LCD_LINE3, "Amarillo");}
           { TextOut (0, LCD_LINE3, "Rojo");}
  Wait(10000);
  for(;j <=4; j++)
  RotateMotor(OUT_A, 100,360);
  color[j] = Sensor(IN_1)
  for(; i<=4; i++)
  {   switch(color[i])
     case 2:
       break;
     case 3:
       TextOut (0, LCD_LINE4, "Verde");
       break;
     case 4:
       TextOut (0, LCD_LINE5, "Amarillo");
       break;
     case 5:
       TextOut (0, LCD_LINE6, "Rojo");
       break;
           if (color[i] != random[i])
           { result +=1;}
  if (result > 0)
   {TextOut (0, LCD_LINE3, "Wrong!");  }
   {TextOut (0, LCD_LINE3, "Well done!");}
  Wait(5000);
Re: NXC memory game not working.
That type of error is often something out of range. (bad parameter)
I believe arrays in NXC are 0-based, so the statement:
int random[4];
creates four elements, numbered 0-3. Looks like changing the statements to:
int random[5];
...should solve the problem. However, keep in mind that you've created an array that is larger than what you need. That's generally not a good programming technique.
hassenplug wrote:...should solve the problem. However, keep in mind that you've created an array that is larger than what you need. That's generally not a good programming technique.
What he means is, use this:
#define ACCESS_ELEMENT(arr,idx) arr[idx-1]
for(unsigned int idx = 1; idx <= 4; idx++)
    ACCESS_ELEMENT(random, idx) = 4; // Look here: http://xkcd.com/221/
(Mentally, of course.)
My recommendation would be to change this:
to this:
    for(v = 0; v < 4 ; v++)
I would also replace "4" with a #define constant named ARRAY_SIZE or something like that so that you do not have what are referred to as "magic numbers" sprinkled throughout your source code. Alternatively, you could call ArrayLen instead of using a hard-coded value.
Forgot to mention that you would also need to start i and j counting at zero instead of 1 and use < rather than <= in the for loops that iterate on i and j.
