A very basic question
hararilior
Post by hararilior »
Ok, this one is very basic.
We've written a very simple program that has a move block(unlimited) after the start edge.
Then later on in the thread there's a wait block (10 secs).
The result was that the robot waited first for 10 secs, and only then started moving.
This was obviusly not our intention, any thoughts?
Thanks,
Lior
aagruntpuddock
Re: A very basic question
Post by aagruntpuddock »
Can you post a copy of the program?
Go to file, print then select print as html. This will create an hmtl file and a .png file. Attach the .png to your post.
hararilior wrote:Ok, this one is very basic.
OK, then you won't get any help from us, because we like challenges. ;)
hararilior wrote: We've written a very simple program that has a move block(unlimited) after the start edge. Then later on in the thread there's a wait block (10 secs). The result was that the robot waited first for 10 secs, and only then started moving.
Are you sure it's connected the way you want it? NXT-G is a bit messed up, so I suggest you create a new program, and do the same thing again.
A .rbt AND a .png would be awesome.
aagruntpuddock
How does one post a .rbt file? I just tried it out of interest and it said 'extension not allowed'.
Tried a .png file created by NXT-G 2.0 and was told it is not a valid file!
Bit of a bummer for a Lego site!
aagruntpuddock wrote:How does one post a .rbt file? I just tried it out of interest and it said 'extension not allowed'.
Post it as a .zip file. If you're running Windows, that's: Right-Click on file, Send To -> Compress (zipped) Folder.
You can use imgur.com for file hosting. The code for the image above is:
[img]http://i.imgur.com/vtugw.png[/img]
aagruntpuddock
OK, thanks . I couldn't see anything which stipulated the acceptable file types.
Just to try it out I attach a trivial little program which displays the NXT battery voltage until you press the right arrow.
Battery Voltage.zip
(96.23 KiB) Downloaded 1058 times
