BigWay stands up and balance
Posted: 26 Dec 2010, 14:22
by charis997
Hi all !
I've just finished my second attempt for a segway type NXT robot which can stands up by itself and balance. It is also able to lie down.
Look at my video. It shows standing up sequence, 10 seconds balance with lever retracting then lie down sequence with releasing the lever.
I am using Hitechnic gyro and acceleration sensor. Acceleration sensor is used to determine vertical position. The values for vertical position were captured experimentaly. It works very reliable as opposit to my first design.
http://www.flickr.com/photos/charis997/5292983742/
regards
Charis
Re: BigWay stands up and balance
Posted: 26 Dec 2010, 16:42
by dudmaster
Great! That's cool
Posted: 27 Dec 2010, 01:09
by loopymech
Wow, that is Awesome!
Posted: 27 Dec 2010, 07:18
by mightor
That's very cool. Would you mind posting your code so people can see what you did ? :)
Posted: 28 Dec 2010, 11:26
by charis997
Hi Xander , hi all
Here is the code.
https://docs.google.com/uc?id=0B-sJxpsF ... d&hl=en_GB
Description and comments inside the code should be sufficient to understand the solution.
Questions are welcomed, comments will be appreciated.
Charis
Posted: 28 Dec 2010, 15:59
by nxtboyiii
Wow. That is very cool. That is the best segway I have ever seen!
Posted: 10 Jan 2011, 21:31
by arqetype
Considering I just got my mindstorms set this Christmas, I think this is risky business. I just keep thinking your nxt may topple over and smash on the floor!
Nice work!
Posted: 10 Jan 2011, 21:40
Notice though, that if it did fall over, the NXT wouldn't touch the floor. There are pieces that stick out on both sides. Also, the whole thing is probably only 10 or so inches tall, not very far to fall.
Posted: 23 Jan 2011, 12:42
by charis997
Of course it fell over. More times during software tuning. "BigWay" is my second model. First one fell over quite often.
Some other segway robots are using gum parts to soften the fall. Nevertheless NXT brick is not so fragile and successfully survived all my experiments.
Posted: 23 Jan 2011, 12:48
by mightor
I've had my segway robots run right off the table at full speed at demos :) That's about 3ft down and I've never broken an NXT...yet.
