Okay, I know how to write multiple lines into a file on the NXT, and it's proven very helpful in creating readable .txt datalogs. What my question is, is it possible for the NXT to retrieve information from a file in any of the written lines instead of just the last recorded line? And also, is it possible to accurately retrieve data from a .txt file? Thanks
Botmaster
Re: Reading from multiple lines in a File
Posted: 21 Dec 2010, 20:51
Well, with NXC, Yes, and Yes.
Posted: 21 Dec 2010, 21:33
by muntoo
logebotmaster wrote:Hi,
Matt, I think that the OP was also asking "how".
Assuming it's in string format, you may want to check out ReadLnString().
Posted: 21 Dec 2010, 21:43
by muntoo
I can't edit my post...
Anyways, here it is again:
@Matt, I think that the OP was also asking "how".
if(OpenFileRead("File.txt", size, handle) == NO_ERR)
until (Sdone == true) // read the text file till the end
if(ReadLnString(handle,message) != NO_ERR) Sdone = true;
//You need to grab the message and write it to another string(or whatever you need to do) all right here.
//Base it on an increasing variable, like the following lines.
TotalMessage[i]=message;
i++
i++
[/quote]
I need to write this to the variable "Sen". Can you modify this
program to do this?
And how does muntoo do the "Show" thing????
Posted: 22 Dec 2010, 00:42
by muntoo
program to do this?
One of these buttons contains the answer. Actually, they all do.
Anyways, enough fooling around before Xander gets tempted to remove the "Show button" . Here's what you want, assuming that Sen is an array of strings:
