Reading from multiple lines in a File
logebotmaster
Post by logebotmaster »
Okay, I know how to write multiple lines into a file on the NXT, and it's proven very helpful in creating readable .txt datalogs. What my question is, is it possible for the NXT to retrieve information from a file in any of the written lines instead of just the last recorded line? And also, is it possible to accurately retrieve data from a .txt file? Thanks
Botmaster
Re: Reading from multiple lines in a File
Well, with NXC, Yes, and Yes.
logebotmaster wrote:Hi,
Matt, I think that the OP was also asking "how".
Assuming it's in string format, you may want to check out ReadLnString().
I can't edit my post...
Anyways, here it is again:
@Matt, I think that the OP was also asking "how".
I believe it works like this:
void ReadLines(string &out[], string filename)
    byte handle;
    unsigned int fsize;
    ArrayInit(out, "", 0);
    if(OpenFileRead(filename, fsize, handle) == LDR_SUCCESS)
        // Yes, I know I'm becoming more and more like the guys at IOCCC
        for(string szBuf; (ReadLnString(handle, szBuf) == LDR_SUCCESS); ArrayBuild(out, out, szBuf));
        CloseFile(handle);
I suppose you are likely right. Here is an example of the method I use.
if(OpenFileRead("File.txt", size, handle) == NO_ERR)
  until (Sdone == true)  // read the text file till the end
    if(ReadLnString(handle,message) != NO_ERR) Sdone = true;
    //You need to grab the message and write it to another string(or whatever you need to do) all right here.
    //Base it on an increasing variable, like the following lines.
    TotalMessage[i]=message;
    i++
dudmaster
Post by dudmaster »
[quotename=mattallen]
    i++
[/quote]
I need to write this to the variable "Sen". Can you modify this
program to do this?
And how does muntoo do the "Show" thing???? :evil:
2Labz.com, My Website
dudmaster wrote: I need to write this to the variable "Sen". Can you modify this
program to do this?
One of these buttons contains the answer. Actually, they all do.
[spoiler][url=http://xkcd.com/109/][spoiler][img]http://imgs.xkcd.com/comics/spoiler_alert.png[/img][/spoiler][/url]
I use spoilers
Anyways, enough fooling around before Xander gets tempted to remove the "Show button" ;). Here's what you want, assuming that Sen is an array of strings:
    byte handle;
    unsigned int fsize;
        CloseFile(handle);
    string Sen[];
    ReadLines(Sen, "File.txt");
dudmaster
Post by dudmaster »
Sen is a string (not array). I like your idea. Thanks... half
dudmaster wrote:Sen is a string (not array). I like your idea. Thanks... half
If Sen is JUST a string, I don't get why you don't just do this:
OpenFileRead(fname, fsize, handle);
Read(handle, Sen);
//Or if that doesn't work:
ReadBytes(handle, fsize, Sen);
//Or
char cSen[];
ReadBytes(handle, fsize, cSen);
CloseFile(handle);
logebotmaster
Thanks all, very interesting indeed.
Botmaster
