How to compile firmware v1.29 with IAR-cc?
Posted: 20 Dec 2010, 20:24
LEGO distributes the NXT firmware as binary also as source code. I installed the free IAR compiler toolchain (v4.42) and tried to compile this source code.
There are two workbench-files (LMS-ARM and LMS-V02) which produce slightly different binaries. Even worse none of those binaries is equal to the binary delivered by LEGO. I know the file system is added at the original firmware - I already cut that part of. It still differs.
Why are they different? How can I get exactly the LEGO binary? What compiler is LEGO using? Really the "old" 4.42 or did they upgrade to 6.??
Thank you for the answers
Bye marvin
Bye marvin
