Displaying an analog clock
How do you display an analog clock on the NXT, using NXC? I know how to use the draw circle function, and I know how to draw lines, but how do I draw a line that starts at the center of the circle, and goes to one of 360 positions (or however many), without entering all the values manually? What math function do I need to perform?
Re: Displaying an analog clock
Actually, I think what I want, is to know the math that is used to write a 2D array of values, used to plot a circle.
Is this within a RIC file?
If not, just use trigonometry!
I'm a getting bit shaky with my NXC now, so here's some pseudo-code:
int xCenter = 50;
int yCenter = 32;
int radius = 20;
float angle = Pi/6 * hour;
drawLine(xCenter, yCenter, xCenter + radius * sin(angle), yCenter + radius * cos(angle));-
Well, I can't say as though I know much of any trigonometry. Thanks a lot, that seems to be almost exactly what I want.
It's a pretty "simple" algorithm, actually. It uses the Pythagorean Theorem, which I expect you've heard of. It's called the Midpoint Circle Algorithm which uses a similar method to Bresenhan's Line Algorithm. It's very fast for non anti-aliased graphics (aka monochrome display).mattallen37 wrote:Actually, I think what I want, is to know the math that is used to write a 2D array of values, used to plot a circle.
I've written a few versions for NXC (including stealing Ellipse code [when I couldn't find what I was looking for] off the EF source
What you want is this:
inline LocationType GetCircleVectorOfTerriblyLongNamesForSimpleFunctionsDeg(float deg, float radius)
LocationType ltTemp;
ltTemp.X = cosd(deg) * radius;
ltTemp.Y = sind(deg) * radius;
return(ltTemp);
m-goldberg
Muntoo, you meant to write "Temp.Y = sind(deg) * radius;" not "Temp.Y = sin(deg) * radius;", right?
Regards, Morton
Shhh! Only the Secret Order Of The Volcano is supposed to know that, remember?m-goldberg wrote:Muntoo, you meant to write "Temp.Y = sind(deg) * radius;" not "Temp.Y = sin(deg) * radius;", right?
We are always watching...muntoo wrote:Shhh! Only the Secret Order Of The Volcano is supposed to know that, remember?
